    SU 9 Wishlist
    436 Posts 99 Posters 181.7k Views 99 Watching
    • pbacotP
      Thanks for the offer Jeff. I've attached some screenshots. Peter
      Plugin Screenshots.zip
      • O
        otb designworks
        @pbacot said:
        Also unlike other Mac apps. It always asks to save when closing the new default file--when I have done nothing at all yet.
        that's caused by a plugin.. if you give me a list of your plugins (or screenshot of the plugin folder), i'll tell you which one is doing it..
        [basically, the plugin does something to the raw document so in effect, you have done something to the file]
        I had no idea this was a plugin thing. I would love to make this annoying behavior go away, so here is my list for analysis, too.
        Cheers, Chuck
        OTB Designworks is on Youtube
        • jeff hammondJ
          @ Peter & Chuck..
          wow, i thought i knew all of the problem rubies in this dept but apparently not 😄
          i don't recognize any of those as being problems (well, skindigo causes it Peter but since you don't have skindigo.rb in the plugin folder, it's not actually loading... fwiw, i do have a workaround for skindigo because it's my rendering app of choice so i spent a few hours tinkering with it in order to be able to use it without this save/dont save issue.. all of the other problem plugins, i just don't use)
          do either of you by chance have plugins also installed in the user directory? there may be an .rb in there that's causing this as well..
          one way to get a clue as to which one is causing it is to:
          open a new su window.. notice the red close button has a darker red dot in the middle.. if the file will close without the save/don't save dialog then the red button will not have the darker dot.. the darker red dot means something has been done to the file.. this isn't sketchup specific and happens in all osx apps.. (well, except for the newer apps that are hooked up to lion's versioning)
          so, assuming you open the new su window and the darker red dot is present, undo (⌘Z) until the smaller red dot disappears.. notice that you'll now be able to close the file without the save/don't save dialog..
          with a fresh su window, look under the Edit menu and the Undo choice there will list what it is that you're undoing.. (for instance, if i draw a line then look under the edit menu, i'll have a choice to 'Undo Draw Line')..
          what does it say that you're undoing?
          • O
            otb designworks
            So of course, for the first time in recorded history, my new files are closing without the save dialogue.
            Never, ever seen it do that before!? It is like the darn thing is paying attention or something. Or maybe the screenshot I took of the plugins folder freaked it into behaving:)
            Thanks for the undo heads up; I will pay attention to that once the behavior reverts to normal.
            Cheers, Chuck
            • wind-borneW
              wind-borne
              @pbacot said:
              And I wish that when I open a recent doc from the recent file dropdown, and then save as, it defaults to the location of the last document I opened with the open file dropdown, and not the one that I just opened. Wastes a lot of time navigating file structures to where I need to save as to.
              I wonder if this is a SU or MacOS thing. Do you find other apps act differently?
              that's a sketchup thing and it IS annoying... what happens is when you open a file using the open dialog (File -> Open...), the Save As... dialog will now always default to that as the save location.. even across sessions..
              you might check tools folder also as LU presented the same save when you had done nothing issue at one time
              a bit pricey yet nevertheless valuable is Default Folder X for the Save As issue
              "To read between the lines was easier than to follow the text."OSX 10.11.6
              %(#BF80BF)[SU 8 pro
              • jgbJ
                jgb
                It is a Windows "thing" not SU that resets your default directory on a "save as". Drives me nuts when I d/l something from the net to a specific dir, then my next "save to" from any app goes there too. 🤢
                jgb
                • Bob JamesB
                  Bob James
                  Some way to handle a lot of plugins so the right click menu doesn't get greyed out.
                  I'm more than a little tired of having to take out half, see if the "bad guy" was in that half, put part of them back in, check again, etc. etc. etc.
                  I'm not a "plugin pack-rat" or a masochist wanting to constantly have greyed-out right click menu search and destroy exercises. So why should I be limited on the number of plugins I have? I wouldn't have them loaded if I didn't use them (granted some more often than others, but none that I don't use at least some times for special needs).
                  I'd better stop, this is turning into a rant. 😄
                  • jgbJ
                    jgb
                    What irks me most about plugins in general is there is no consistency or logic to where their controls go… rt-click, plugin menu, own toolbar (somewhere on the screen) or buried in some other menu item.
                    SU needs a menu item or plugin (the irony does not escape me) that lists all plugins and where to find their controls. While we are at it include the authors name in that list. Many a time I need to ask here a question/pose a problem and I gotta open the script to see who wrote it.
                    jgb
                    • O
                      obkcaptain
                      Hi all
                      I like the new SK may vary the width of the lines and their appearance (dots, dashs, etc.) and that could change the color of the lines without using extruded circles
                      Sorry if this was asked before. Or there's a plugin (always plugings for all)
                      In this case, Please Mr Moderator, erase this post.
                      • AdamBA
                        AdamB
                        Open SketchUp Preferences->Extensions and click on the plugin name to get a short description and info about author/company etc.
                        Adam
                        • mitcorbM
                          mitcorb
                          @obkcaptain: for linestyles, see TIG's 2D tools. As for lines in color, can you not color by layer?
                          EDIT: Also, perhaps ColorBy--by sdmitch.
                          • P
                            publied
                            any news about a 8.1 or a 9 release?
                            ciao
                            hire me@ http://www.publied.it !
                              ciao
                              SketchUp release dates are never announced in advance.
                              • jeff hammondJ
                                i tried the trial version of that a while ago.. i can't remember why i didn't buy it but i know i didn't like it enough to purchase it..
                                personally, i just keep any major project folders in the finder sidebar so they're always available in the save dialog.. just click on one and it will save there.. another thing you can do which i don't think too many people know about is to drag a folder and drop it anywhere on the save dialog which will switch the save location to that folder.. you need to be able to see the folder somewhere on screen but if you're set up for it, it's a pretty handy way to navigate the file structure.
                                • pbacotP
                                  Would like to see View Sections and Section Planes be dissassociated from Styles. Make it a scene choice only.
                                  • jeff hammondJ
                                    i know i've seen this request before (and probably in this thread) but...
                                    please make a toggle key to lock direction of the move tool (or line etc..) in any direction you wish.. it seems like such a no brainer to have it work like that instead of holding the shift key down to lock.. and even then, you can't lock in any direction.. only if it's an axis or along a line..
                                    you should be able to move to a point, click the toggle, and you will be locked on the vector from the original point through the secondary point.
                                    • pbacotP
                                      I would like a command to dock all floating windows collapsed, (except the drawing window and the colors) in Mac. For example take the top most window (in screen position) as an anchor and move all open windows to be attached under it, in collapsed form (not collapsed could be an option).
                                      Changing monitors makes keeping the windows straight a pain.
                                      I wish the Colors window would go away when the bucket tool is deselected. It serves no purpose being open.
                                      • utilerU
                                        utiler
                                        Here's my wishlist... had a little fun putting it together. 😉
                                        SketchUp-MyLowHangingFruit.pdf
                                        Just Curious...
                                        • utilerU
                                          utiler
                                          Not sure what happened to that one; something wrong with it apparently... try this one.
                                          SketchUp8-MyLowHangingFruit.pdf
                                          Just Curious...
                                          • L
                                            luke catt
                                            A component tool like the material tool.
                                            Instead of painting the face with a material, it changes it to your selected component. ie brick etc.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 21
                                            • 22
                                            • 13 / 22
