    Sudden ding/chime when clicking mouse wheel
    15 Posts 6 Posters 713 Views 6 Watching
      CalypsoArt
      @chris fullmer said:
      This is due to some plugin that you've installed. Can you think of any plugin you've installed recently?
      You could also search your plugins folder for any file with the text beep, or UI.beep. And if its on a lingle line, just place a # in front of it.
      Is this a search plugin by plugin, or is there a search that will be able to look at the text in all the rubys at once?
        First see if you have housbuilder.rb and search there. If you don't, search elsewhere, too
          What OS? You should be able to search your computer or at least specific areas for that text.
            CalypsoArt
            WIN 7 64. In the general search box, or with some switches added.
            I do have the housbuilder plugin but not installed in the plugin folder.
              If Housebuilder isn't in the Plugins folder, it won't be loading with SketchUp so it wouldn't be responsible for the dings.
              Go to Windows (button, lower left corner)>Search>For Files or Folders. You should be able to search for files containing the text beep.
                CalypsoArt
                Found it.
                jf_audible_tool_click.rb
                Removed the ruby and the ding is gone.
                  Was that part of another tool?
                  • Chris FullmerC Offline
                    Yeah, Its part of Jim Foltz's jf_annoy_the_crap_out_of_everyone.rb toolset 🤣
                        You don't always need EVERY script that's written... use your judgment 😒
