    Sudden ding/chime when clicking mouse wheel
    15 Posts 6 Posters 436 Views 6 Watching
      CalypsoArt
      I'm not sure what happened. I use a Wacom tablet, and suddenly in SU when I press down on my mouse wheel, (Rotate tool) it ding/chimes. This never happened before. I'm not sure where to find the setting to switch this off. It only happens in SU. Suggestions?
      • Chris FullmerC Offline
        This is due to some plugin that you've installed. Can you think of any plugin you've installed recently?
        You could also search your plugins folder for any file with the text beep, or UI.beep. And if its on a lingle line, just place a # in front of it.
          Sounds like christmas has arrived.
            It should be housebuilder.rb (if Chris is right)
              CalypsoArt
              Thanks will do a search.
                CalypsoArt
                Is this a search plugin by plugin, or is there a search that will be able to look at the text in all the rubys at once?
                  First see if you have housbuilder.rb and search there. If you don't, search elsewhere, too
                    What OS? You should be able to search your computer or at least specific areas for that text.
                      CalypsoArt
                      WIN 7 64. In the general search box, or with some switches added.
                      I do have the housbuilder plugin but not installed in the plugin folder.
                        If Housebuilder isn't in the Plugins folder, it won't be loading with SketchUp so it wouldn't be responsible for the dings.
                        Go to Windows (button, lower left corner)>Search>For Files or Folders. You should be able to search for files containing the text beep.
                          CalypsoArt
                          Found it.
                          jf_audible_tool_click.rb
                          Removed the ruby and the ding is gone.
                            Was that part of another tool?
                              Yeah, Its part of Jim Foltz's jf_annoy_the_crap_out_of_everyone.rb toolset 🀣
                                  You don't always need EVERY script that's written... use your judgment πŸ˜’
