    Vray for sketchup render and save individual frames
    renderpluginsextensions
    13 Posts 8 Posters 16.9k Views 8 Watching
      ledisnomad
      I think you are looking for this: http://forums.sketchucation.com/viewtopic.php?f=322&t=25028&p=216267&hilit=+batch+render+vray#p223947
      There is a checkbox in the save image area that appends sequential numbers. If you have everything else set up correctly (which is also covered in the above thread), it should render one image per scene and save them with YourFileName0000.png, YourFileName0001.png, ...
      Hope that helps!
        ledisnomad
        There are so many options, it's easy to overlook any particular one. 😄
        • eidam655E Offline
          eidam655
          of course - 'Include Frame Number'
          thank you very much, i can't believe i overlooked this option ^^
          //so, for my future reference, when i have a model with set scenes and i want VRay to automatically make 1 render of each scene (ie. at architectural visualisation), i have to set up SketchUp (Object info -> Animation -> enable scene transitions (1 sec), scene delay = 0) and VRay (save file ON, filetype image, Animation ON, Include frame number, FPS 1)
          I'm using SketchUp 2017, V-Ray 3.4
          • halroachH Offline
            halroach
            I'm trying to render individual frames with vray for an animation.
            I've ticked what needs to be ticked... save file, include frame number, fps, etc.
            vray renders each of the images but refuses to save each of the images rendered in the specified folder, not even the first image.
            any suggestions?
            I'm using vray 1.48.96
            FlexTools - Super Quick Windows, Doors, Slats...
            • dkendigD Offline
              dkendig
              The old forums are migrated, but are not visible if your account hasn't been properly registered on the chaos group site. Contact our support department if you are not able to see all of the old forums in the new chaos group website.
              Devin Kendig
              Developer
              • andybotA Offline
                andybot
                any suggestions?
                Are you able to render without the animation option? It may be something is preventing a render (memory issues, materials, etc.) which may not necessarily be an issue with animation...
                • halroachH Offline
                  halroach
                  any suggestions?
                  Yes, I am able to render without the animation option.
                  Though I have the same problem in a single render that I cannot autosave the output. I can only save it by clicking on the save icon.
                    kirikeilek
                    I encountered this problem too. I can't find any solution.
                      rspierenburg
                      You could try updating to the newest version (1.49.01). It might have been a bug corrected in that version.
                        kirikeilek
                        Thanks for the tip. I guess it worked. tested out the autosave option in the output and animation and its working.
                        Thanks again. =D
                        • dkendigD Offline
                          dkendig
                          don't forget to register on the Chaos Group forums, all of the content from our old ASGvis forums have been migrated to the new Chaos Group forums. If you have trouble registering, or you can't see all of the content on the forum, please contact support@chaosgroup.com so we can get your account straightened out.
                          Devin Kendig
                          Developer
                          • N Offline
                            nomeradona
                            Yes the site is working perfectly...
