    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      AcesHigh
      @thomthom said:
      Looking at the one you sent, I selected everything and intersected it with itself a few times. CleanUp doesn't clean up faces that partially overlaps. Only faces that fully cover the exact same space as another. After intersecting and then cleaning there was no overlapping.
      I will try that, thanks... however... how can I intersect if they are not solids?
      ps: I am trying to solve, with CleanUp, about the same problem that made me ask for the "GoogleEarth Meshes boolean subtract" plugin at the topic http://forums.sketchucation.com/viewtopic.php?f=323&t=40555
        Not intersecting with Solid Tools, but the regular intersect that's been in SU since, ever..? From the context menu, there is Intersect Faces menu item.
          AcesHigh
          since ever, but I had never seen or used it before 😆
          anyway, however, intersected it with itself several times, and when I used cleanup³, several triangles were lost, and got some error messages 😢
            What where the error message?
              AcesHigh
              something along these lines (not exactly the same because I had to test again, with new Earth imported meshes, so different triangles disappeared, etc)
              Results of Validity Check.
              CEdge (4234) and CEdge (7926) connect the same 2 vertices - fixed
              The plane equation for CFace (4767) is not valid - fixed
              35 errors occurred. Please report the error and sample model to the author.
              35 - Face merge resulted in lost geometry!
              • sumasterS
                sumaster
                Dear Thomthom Sir,
                here you are launch your new Cleanup (3.1.8) — 06 October 2011
                • Whats new features you are added ❓
                and one problem can you solve in new version
                I'm architectural student and import CAD drawing and lock that drawing in sketchup viewport
                but when i play / start " Clean With Last Setting " he also cleanup viewport with lock group/component 😮
                See here ......
                Regular selection
                Lock selection
                Finally clean every thing .....
                And thank you for this tool its very best for me or ever one ...... 😄 😉
                I'm very happy with this tool ......
                Thank you,
                SUmaster
                  The way CleanUp traverses the model it's tricky to know what is part of a locked group or not. But I'll put it down for investigation.
                  • sumasterS
                    sumaster
                    Yes thank you .....
                    Thank you,
                    SUmaster
                    • dereiD
                      derei
                      You can use ruby to check if is locked or not
                      http://code.google.com/apis/sketchup/docs/ourdoc/group.html#locked?
                      http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#locked?
                      DESIGNER AND ARTIST DEREI.UK
                        I know, but, I traverse the model by model.definitions.each - which means that I do not know if the parent for the instances I traverse are locked. I could be checking a sub-group of a locked group and .locked? will return false.
                        • T
                          Tahesco
                          Hi ThomThom,
                          We imported a 100mb model from ARCHICAD into SU (in fbx format). This goes slow but it works.
                          The problem is the same material gives different uvw_sizes on my components. The same brick material is 1 cm on a component while it's neigbour component has bricks of 20 cm ?!?.
                          Is there a way to reset all components to the same scale, so my bricks are uniform on all objects/ components? (like reset xform in 3dsmax)
                          Thanks for all the usefull work!
                          TTion
                          • bagateloB
                            bagatelo
                            Another thing to do would be also interesting can recursively set all groups and components to "scale definition."
                            @tahesco said:
                            Hi ThomThom,
                            TTion
                              And how would you handle scenarios where one definition has instances of different scale... ?
                              • T
                                Tahesco
                                In my case I don't care if I loose all instances. All scene objects may become true default geometry. (because my scene objects are build in ARCHICAD).
                                Thanks again,.
                                NB -> Maybe an object replacer-script is capable of repairing killed Insances in a SU scene,...
                                • sumasterS
                                  sumaster
                                  Hello Tahesco,
                                  can you CHK Unit ... when you export the file from ARCHICAD into .fbx format
                                  so 1st CHK and again import that .fbx file into the sketchup same unit select ......
                                  thanks
                                  Thank you,
                                  SUmaster
                                  • sumasterS
                                    sumaster
                                    yes sir you are right .......
                                    when run Cleanup last setting he CHK all group or component ..... right ...?
                                    Thank you,
                                    SUmaster
                                    • genma saotomeG
                                      genma saotome
                                      VERY useful! 😍 My thanks for producing and releasing this.
                                      Might you consider adding "Remove Materials" from Backface? I know it's in another plugin but it's something I should do as part of my final cleanup but I often forget. Adding this would to Cleanup would be real handy and I would like to see the count of cleaned backfaces in the statistics too.
                                      P.S.
                                      Ya know, adding "Remove Untextured Faces" would be a godsend for me. Any chance of that too?
                                      • 0
                                        0devang
                                        It doesn't work with sketchup pro 8. what could be the reason?
                                          The plugin does indeed work with SketchUp 8 Pro. If it isn't working for you, the most likely cause is that it hasn't been installed correctly. Go back to the first post and read the instructions and make sure it has been installed correctly. This includes installing TT_Lib2 as indicated under Requirements.
                                            P.S.
                                            I'll see what I can do for the next release. (I'm quite busy atm, can't promise anything.)
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 48
                                            • 49
                                            • 24 / 49
