    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      Also, what are your settings?
        That model is after CleanUp is run? You got the original?
          AcesHigh
          what settings ThomThom? The ones from CleanUp³?
          everything selected except Geometry to Layer 0, Merge Identical Materials (its two different materials, a bitmap for each imported mesh), so I saw no reason to use it) and Erase Stray Edges.
          sorry, I didnt keep the original imported meshes. But I will try again with new imported meshes.
            Looking at the one you sent, I selected everything and intersected it with itself a few times. CleanUp doesn't clean up faces that partially overlaps. Only faces that fully cover the exact same space as another. After intersecting and then cleaning there was no overlapping.
              AcesHigh
              here... I copied the two meshes and joined them in a group, exploded them, and used Cleanup. No lost triangles this time, but there are plenty of overlapping triangles. (sometimes they dont appear when viewing in the textured mode, but when you used SHADED mode you will see the overlapping triangles...)
              of course, the problem gets worse when you have to import even more mesh pieces, as sometimes you have over 3 meshes overlapping.
              experimento3.skp
                AcesHigh
                I will try that, thanks... however... how can I intersect if they are not solids?
                ps: I am trying to solve, with CleanUp, about the same problem that made me ask for the "GoogleEarth Meshes boolean subtract" plugin at the topic http://forums.sketchucation.com/viewtopic.php?f=323&t=40555
                  Not intersecting with Solid Tools, but the regular intersect that's been in SU since, ever..? From the context menu, there is Intersect Faces menu item.
                    AcesHigh
                    since ever, but I had never seen or used it before 😆
                    anyway, however, intersected it with itself several times, and when I used cleanup³, several triangles were lost, and got some error messages 😢
                      What where the error message?
                        AcesHigh
                        something along these lines (not exactly the same because I had to test again, with new Earth imported meshes, so different triangles disappeared, etc)
                        Results of Validity Check.
                        CEdge (4234) and CEdge (7926) connect the same 2 vertices - fixed
                        The plane equation for CFace (4767) is not valid - fixed
                        35 errors occurred. Please report the error and sample model to the author.
                        35 - Face merge resulted in lost geometry!
                        • sumasterS
                          sumaster
                          Dear Thomthom Sir,
                          here you are launch your new Cleanup (3.1.8) — 06 October 2011
                          • Whats new features you are added ❓
                          and one problem can you solve in new version
                          I'm architectural student and import CAD drawing and lock that drawing in sketchup viewport
                          but when i play / start " Clean With Last Setting " he also cleanup viewport with lock group/component 😮
                          See here ......
                          Regular selection
                          Lock selection
                          Finally clean every thing .....
                          And thank you for this tool its very best for me or ever one ...... 😄 😉
                          I'm very happy with this tool ......
                          Thank you,
                          SUmaster
                            The way CleanUp traverses the model it's tricky to know what is part of a locked group or not. But I'll put it down for investigation.
                            • sumasterS
                              sumaster
                              Yes thank you .....
                              Thank you,
                              SUmaster
                              • dereiD
                                derei
                                You can use ruby to check if is locked or not
                                http://code.google.com/apis/sketchup/docs/ourdoc/group.html#locked?
                                http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#locked?
                                DESIGNER AND ARTIST DEREI.UK
                                  I know, but, I traverse the model by model.definitions.each - which means that I do not know if the parent for the instances I traverse are locked. I could be checking a sub-group of a locked group and .locked? will return false.
                                  • T
                                    Tahesco
                                    Hi ThomThom,
                                    We imported a 100mb model from ARCHICAD into SU (in fbx format). This goes slow but it works.
                                    The problem is the same material gives different uvw_sizes on my components. The same brick material is 1 cm on a component while it's neigbour component has bricks of 20 cm ?!?.
                                    Is there a way to reset all components to the same scale, so my bricks are uniform on all objects/ components? (like reset xform in 3dsmax)
                                    Thanks for all the usefull work!
                                    TTion
                                    • bagateloB
                                      bagatelo
                                      Another thing to do would be also interesting can recursively set all groups and components to "scale definition."
                                      @tahesco said:
                                      Hi ThomThom,
                                      TTion
                                        And how would you handle scenarios where one definition has instances of different scale... ?
                                        • T
                                          Tahesco
                                          In my case I don't care if I loose all instances. All scene objects may become true default geometry. (because my scene objects are build in ARCHICAD).
                                          Thanks again,.
                                          NB -> Maybe an object replacer-script is capable of repairing killed Insances in a SU scene,...
                                          • sumasterS
                                            sumaster
                                            Hello Tahesco,
                                            can you CHK Unit ... when you export the file from ARCHICAD into .fbx format
                                            so 1st CHK and again import that .fbx file into the sketchup same unit select ......
                                            thanks
                                            Thank you,
                                            SUmaster
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 48
                                            • 49
                                            • 24 / 49
