    [Plugin] QuadFaceTools
    673 Posts 116 Posters 524.7k Views 116 Watching
    • dereiD Offline
      derei
      I wasn't aware that you released a fixed version. I don't know how to check the version (it doesn't appear in toolbar's name, or anywhere else). So I reinstalled the plugin, with one I downloaded now and it works just fine.
      Thank you very much.
        @gilles said:
        SU 8.0.3161
        have to update?
        I'd recommend that you do. Always keep your software up to date.
        However, for the mapping problems you have been experiencing. I think I might have found it. It's due to a bug in TT_Lib2.5 which I have fixed in the unreleased TT_Lib2.6. (I'd forgotten I'd fixed this bug which affected QuadFace Tools.)
        Keep an eye out for an update to TT_Lib2.
          When you go to Window > Preferences > Extensions you can find the version from there.
          I'll add an About menu to the next version.
          Btw, QuadFace tools now supports Fredo's update checker.
          • dereiD Offline
            derei
            If you want to add it only for version, you can add version in toolbar name.
              Nah - I don't want to add version to menus and toolbars. Because then shortcut keys would break at every update. SketchUp reference them by their names.
                Important!
                All users should update TT_Lib2 to version 2.6.0
                  Thank You
                    πŸ‘
                    • gillesG Offline
                      gilles
                      it's ok now with TT_LIB 2.6 it is not yet in plugin index so i had 2.58
                      thanks
                        I released TT_Lib2 2.6 just a few hours ago... πŸ˜‰
                        • fredo6F Offline
                          @thomthom said:
                          Tom,
                          Here is the model where I have problem (I get the UV axes, but the texture does not appear).
                          [attachment=0:3fo0zvrn]<!-- ia0 -->Quad-mapping Fred.png<!-- ia0 -->[/attachment:3fo0zvrn]
                          Might be related to the nil errors people are reporting...
                          This is the message I get
                          Error; #<TypeError; nil can't be coerced into Float>
                          D;/Documents/Doc/AA_SKU/Ruby/AAA_SCRIPT6/TT_QuadFaceTools/uv_mapping.rb;820;in `/'
                          D;/Documents/Doc/AA_SKU/Ruby/AAA_SCRIPT6/TT_QuadFaceTools/uv_mapping.rb;820;in `point_on_axis'
                          EDIT: this is with v0.4. I did not upgrade yet
                          • fredo6F Offline
                            @charly2008 said:
                            Hi Fredo,
                            I think you need before placing the texture on the face. Then you can scale the texture. Whether it is possible to be centered I do not know.
                            Thanks. Once I have the texture on the shape, what should I do next?
                              How about 0.4.1?
                              (I'm prepping up 0.5 which included quite a few validations and error catching. Should be more informative when things doesn't work.)
                              Then you can click the axis (red and green line) to scale it. Or use the VCB.
                                jorge2011
                                thom excellent, now works fine.
                                thank you very much for your fast response
                                • charly2008C Offline
                                  charly2008
                                  I made another attempt with my Viking ship hull. This tool is really amazing. A small error I could not resolve.
                                  wiking.skp
                                    huh! ... peculiar... I'll look into it.
                                    Nice boat! πŸ˜„
                                      How did you map it? With the UV Mapping tool, or with the UV Copy & Paste tools?
                                        I found the cause - you got some messed up geometry there.
                                        Look at this screenshot:
                                        Here I made a left to right selection over the selected quad. Notice the Entity Info correctly displaying 7 entities. ( 2 triangles, 5 edges )
                                        Now look at this one - where I made the same selection around the troublesome area:
                                        Notice there is 20 (!) entities. Something is messed up in your geometry there.
                                          Zoom in to the top left corner of that white and see a whole lot of extra edges and faces
                                            Version 0.5.0
                                            Changelog: https://bitbucket.org/thomthom/quadface-tools/issues?status=resolved&version=0.5.0
                                            Download: https://bitbucket.org/thomthom/quadface-tools/wiki/Download
                                            • 33
                                            • 34
                                            • 4 / 34
