    [Plugin] QuadFaceTools
    680 Posts 116 Posters 713.8k Views 116 Watching
    • dereiD Offline
      derei
      Hello thomthom, do you have any answer related to the error I mentioned here http://forums.sketchucation.com/viewtopic.php?f=323&t=39442&start=75#p358895 ? Now it happens every time I start SU. I don't know why at first happened only on second instance.
      DESIGNER AND ARTIST DEREI.UK
      • gillesG Offline
        gilles
        I get similar result than Jorge with a simple cylinder.
          You still get that? I thought I'd fixed it in 0.4.1 ...
          Can you do a load 'tt_quadface.rb' again and report back the error message?
          You're using SU8, right? (Updated Maintenance release 1?)
          And TT_Lib2 version ... ?
            I cannot reproduce this at all. Here's what happen when I try to map the cylinder with continuous mapping: http://www.youtube.com/watch?v=aAWK4TcGn2E
            I tried all modes, and with the faces selected and nothing selected...
            Can you post a screenshot or video?
            • gillesG Offline
              gilles
              I got this.
                And both of you got QuadFace Tools 0.4.1, and TT_Lib 2.5.8? Using SketchUp 8? (Maintenance release 1?) You got admin rights? 100% sure the plugin has been updated? (Under Vista and Win7 there a Compatibility Files feature that puts files in a ghost folder - it has caused issues from time to time when...)
                • gillesG Offline
                  gilles
                  SU 8.0.3161
                  have to update?
                  • dereiD Offline
                    derei
                    I wasn't aware that you released a fixed version. I don't know how to check the version (it doesn't appear in toolbar's name, or anywhere else). So I reinstalled the plugin, with one I downloaded now and it works just fine.
                    Thank you very much.
                      @gilles said:
                      SU 8.0.3161
                      have to update?
                      I'd recommend that you do. Always keep your software up to date.
                      However, for the mapping problems you have been experiencing. I think I might have found it. It's due to a bug in TT_Lib2.5 which I have fixed in the unreleased TT_Lib2.6. (I'd forgotten I'd fixed this bug which affected QuadFace Tools.)
                      Keep an eye out for an update to TT_Lib2.
                        When you go to Window > Preferences > Extensions you can find the version from there.
                        I'll add an About menu to the next version.
                        Btw, QuadFace tools now supports Fredo's update checker.
                        • dereiD Offline
                          derei
                          If you want to add it only for version, you can add version in toolbar name.
                            Nah - I don't want to add version to menus and toolbars. Because then shortcut keys would break at every update. SketchUp reference them by their names.
                              Important!
                              All users should update TT_Lib2 to version 2.6.0
                                Thank You
                                  • gillesG Offline
                                    gilles
                                    it's ok now with TT_LIB 2.6 it is not yet in plugin index so i had 2.58
                                    thanks
                                      I released TT_Lib2 2.6 just a few hours ago... 😉
                                      • fredo6F Offline
                                        @thomthom said:
                                        Tom,
                                        Here is the model where I have problem (I get the UV axes, but the texture does not appear).
                                        [attachment=0:3fo0zvrn]<!-- ia0 -->Quad-mapping Fred.png<!-- ia0 -->[/attachment:3fo0zvrn]
                                        Might be related to the nil errors people are reporting...
                                        This is the message I get
                                        Error; #<TypeError; nil can't be coerced into Float>
                                        D;/Documents/Doc/AA_SKU/Ruby/AAA_SCRIPT6/TT_QuadFaceTools/uv_mapping.rb;820;in `/'
                                        D;/Documents/Doc/AA_SKU/Ruby/AAA_SCRIPT6/TT_QuadFaceTools/uv_mapping.rb;820;in `point_on_axis'
                                        EDIT: this is with v0.4. I did not upgrade yet
                                        • fredo6F Offline
                                          @charly2008 said:
                                          Hi Fredo,
                                          I think you need before placing the texture on the face. Then you can scale the texture. Whether it is possible to be centered I do not know.
                                          Thanks. Once I have the texture on the shape, what should I do next?
                                            How about 0.4.1?
                                            (I'm prepping up 0.5 which included quite a few validations and error catching. Should be more informative when things doesn't work.)
                                            Then you can click the axis (red and green line) to scale it. Or use the VCB.
                                            • 33
                                            • 34
                                            • 7 / 34
