    [Plugin] QuadFaceTools
    680 Posts 116 Posters 771.9k Views 116 Watching
      jorge2011
      @thomthom said:
      I see in the video that the origin of the V axis (indicated by the green X) isn't where it should be. Though I do not understand why. I can't make that happen on my test models...
      can you explain a little more?
      • dereiD
        derei
        Hello thomthom, do you have any answer related to the error I mentioned here http://forums.sketchucation.com/viewtopic.php?f=323&t=39442&start=75#p358895 ? Now it happens every time I start SU. I don't know why at first happened only on second instance.
        DESIGNER AND ARTIST DEREI.UK
        • gillesG
          gilles
          I get similar result than Jorge with a simple cylinder.
            You still get that? I thought I'd fixed it in 0.4.1 ...
            Can you do a load 'tt_quadface.rb' again and report back the error message?
            You're using SU8, right? (Updated Maintenance release 1?)
            And TT_Lib2 version ... ?
              I cannot reproduce this at all. Here's what happen when I try to map the cylinder with continuous mapping: http://www.youtube.com/watch?v=aAWK4TcGn2E
              I tried all modes, and with the faces selected and nothing selected...
              Can you post a screenshot or video?
              • gillesG
                gilles
                I got this.
                  And both of you got QuadFace Tools 0.4.1, and TT_Lib 2.5.8? Using SketchUp 8? (Maintenance release 1?) You got admin rights? 100% sure the plugin has been updated? (Under Vista and Win7 there a Compatibility Files feature that puts files in a ghost folder - it has caused issues from time to time when...)
                  • gillesG
                    gilles
                    SU 8.0.3161
                    have to update?
                    • dereiD
                      derei
                      I wasn't aware that you released a fixed version. I don't know how to check the version (it doesn't appear in toolbar's name, or anywhere else). So I reinstalled the plugin, with one I downloaded now and it works just fine.
                      Thank you very much.
                        @gilles said:
                        SU 8.0.3161
                        have to update?
                        I'd recommend that you do. Always keep your software up to date.
                        However, for the mapping problems you have been experiencing. I think I might have found it. It's due to a bug in TT_Lib2.5 which I have fixed in the unreleased TT_Lib2.6. (I'd forgotten I'd fixed this bug which affected QuadFace Tools.)
                        Keep an eye out for an update to TT_Lib2.
                          When you go to Window > Preferences > Extensions you can find the version from there.
                          I'll add an About menu to the next version.
                          Btw, QuadFace tools now supports Fredo's update checker.
                          • dereiD
                            derei
                            If you want to add it only for version, you can add version in toolbar name.
                              Nah - I don't want to add version to menus and toolbars. Because then shortcut keys would break at every update. SketchUp reference them by their names.
                                Important!
                                All users should update TT_Lib2 to version 2.6.0
                                  Thank You
                                  • GaieusG
                                    • gillesG
                                      gilles
                                      it's ok now with TT_LIB 2.6 it is not yet in plugin index so i had 2.58
                                      thanks
                                        I released TT_Lib2 2.6 just a few hours ago... 😉
                                        • fredo6F
                                          @thomthom said:
                                          Tom,
                                          Here is the model where I have problem (I get the UV axes, but the texture does not appear).
                                          [attachment=0:3fo0zvrn]<!-- ia0 -->Quad-mapping Fred.png<!-- ia0 -->[/attachment:3fo0zvrn]
                                          Might be related to the nil errors people are reporting...
                                          This is the message I get
                                          Error; #<TypeError; nil can't be coerced into Float>
                                          D;/Documents/Doc/AA_SKU/Ruby/AAA_SCRIPT6/TT_QuadFaceTools/uv_mapping.rb;820;in `/'
                                          D;/Documents/Doc/AA_SKU/Ruby/AAA_SCRIPT6/TT_QuadFaceTools/uv_mapping.rb;820;in `point_on_axis'
                                          EDIT: this is with v0.4. I did not upgrade yet
                                          • fredo6F
                                            @charly2008 said:
                                            Hi Fredo,
                                            I think you need before placing the texture on the face. Then you can scale the texture. Whether it is possible to be centered I do not know.
                                            Thanks. Once I have the texture on the shape, what should I do next?
                                            • 33
                                            • 34
                                            • 7 / 34
