    [Plugin] Chronolux for Sketchup
    38 Posts 23 Posters 43.0k Views 23 Watching
    • N Offline
      notareal
      Wow! Welcome back, kirill!
      • boofredlayB Offline
        boofredlay
        All I get is "Invalid Parameters" when trying to view the video.
          I edited his video tag so it now works πŸ˜‰
            boofredlay
            Cheers TIG. πŸ‘
            • bazB Offline
              baz
              'SVF and Insolation'.
              I would like to learn more about this, I've done a google on the terms above but I can't find out what they mean, any pointers?
              Ta, baz
                Panga
                Awesome tools !! Thanks a lot!!
                • PixeroP Offline
                  Pixero
                  Is there any way it can take transparent materials in account?
                  In my tests it acts as if a glass surface is opac.
                    kirill2008
                    Yes it is possible. It's necessary to set "Handle transparency" flag in "Global Settings" dialog to "Yes". It is also necessary to pay attention to "Transparency threshold" value.
                    !["Handle transparency" flag in "Global Settings" dialog.](/uploads/imported_attachments/LgeC_handletransp.png ""Handle transparency" flag in "Global Settings" dialog.")
                    This flag is set to "No" by default because it takes a little bit more time to handle transparency so when it's set to "Yes" it slows down script processing.
                    • EdsonE Offline
                      Edson
                      have you tested it on mac? perhaps all one has todo for it to run on mac is to perform a manual installation. if this is the case, could you please instruct us on how to make a manual installation? should I place the whole thing in my plugins folder?
                      http://www.mahfuz.arq.br
                        driven
                        NO...
                        the manual installation requires placing different folders in different locations.
                        the 'Help' button in tools won't work from inside SU so I suggest you 'first' open the 'Help Pages' in safari to check if you want to instal it.
                        to do this 'unzip' Chronolux 1_0 beta.zip and you'll have a new folder Chronolux 1_0 beta,
                        follow the path to Chronolux 1_0 beta/Resources/en-US/chronolux/index.html and double click to open in Safari.
                        If you still want to instal manually he's a pic of the paths...
                        the main files go here
                        Support files go here
                        I haven't tested the whole thing yet, but you do need to turn on the toolbar in 'View' >> 'Tool Palates'
                        • EdsonE Offline
                          Edson
                          thanks, john. it seems easy enough o install. I will give it a try soon.
                            mirale999
                            Wonderful thing! This is a good plugin for me to decide the shape of a building intuitively πŸ˜†
                            "Test face results presenting" can give us one more choice: Pseudo-color map, like that in ecotect,
                            and in qpik's plugin: simple rays, the ray casting is more even and smooth. I think with this great plugin, we can get rid of the ecotect! haha~
                            paranoia is a higher form of awareness...
                              kirill2008
                              Well, actually solar radiation studies is not the only merit of ecotect πŸ˜‰ but thanks anyway πŸ˜†
                              • urgenU Offline
                                urgen
                                ....супСр! πŸ‘ πŸ‘ πŸ‘
                                --pupil forever...------
                                  georglorenz
                                  This is incredible. This is unbelievable awesome. I was amazed by simple rays but now years after. And working with Revit all the time. This is incredible.
                                    georglorenz
                                    Ok this is really interesting and the user interface is just great.
                                    I do understand that it calculates the shading from a specific test point but could you elaborate a little bit on the difference between short rays and long rays and what exactly they do?
                                    Thank you so much / gxl
                                      georglorenz
                                      Oh and then there are construction points and test points? I understand test points but what are construction points? Thank you / gxl
                                      • EarthMoverE Offline
                                        EarthMover
                                        Kirill, looks amazing. I am also trying to find a sketchup plugin method which will chart sun path and perform a reflection/glare study. I need it for solar panel applications to determine the amount of glare produced based on the angle of the panels per geolocation and it's affect on neighboring buildings in a given radius. I was wondering if something like this could be adapted from the tools you have created here, with a similar raytrace, but charting also a single light bounce for a visual representation? Or, if anyone is aware a software/plugin on the market that will accomplish this?
                                        Content Creator at Skapeup
                                          kirill2008
                                          Well it is possible to place construction points using Sketchup "Tape Measure" tool instead of placing test points using Chronolux "Add Test Point..." tool. Then it is possible to select construction points and process all of them at once using "Make Ray Cluster(s)" or "Calculate SVF" commands. So it's just an optional usage scenario.
                                          I think it could be more convenient sometimes to use construction points for some reason.
                                          Short rays and long rays are only for graphical representation of calculation results. It is possible to adjust their length if it is necessary for drawing layout.
                                          Adam, I think, it is possible to implement. I think, I need to read somewhere about how to calculate reflection/glare amount and then think of how to represent calculation results. I suspect, that glare amount depends on direct sunlight duration, but I don't know how exactly. I'm not sure but I guess the other thing, that glare amount depends on, is an angle between sunlight direction and panel plane. In short it is necessary to search for some additional information on this subject.
                                            boilingsnow
                                            Hi,kirill2008
                                            Thank you for your wonderful tools.
                                            Just as brilliant as your earlier plugins such as ControlPoints...
                                            It's sad that most of your earlier plugins dont work in Sketchup 8....Could you please update them? I would pay for these great tools.
