    [Plugin] Chronolux for Sketchup
    38 Posts 23 Posters 45.1k Views 23 Watching
    • K
      kirill2008
      Link to download Chronolux installer for Windows chronolux_1_1_beta.exe
      Link to download zip archive chronolux_1_1_beta.zip
      Description: Extension for Google Sketchup written on Ruby. Its goal is to test insolation duration and SVF.
      Usage:
      1. install the program using installer or unpack files from zip-file:
        • "chronolux_ext.rb" and "Chronolux" folder unpack to Google Sketchup "Plugins" folder
        • "chronolux.strings" and "chronolux" folder from "Resources/en-US" unpack to Google Sketchup "Resources/en-US" forlder
      2. enable "LSS Chronolux Toolbar" Sketchup Main Menu>>View>>Toolbars>> LSS Chronolux Toolbar
      3. open a Sketchup model, where insolation and/or SVF testing is to be made (model has to be geo-located)
      4. add some test points to perform insolation and/or SVF testing
      ver. 1.0. video:
      [flash=640,480:2a6ahgcy]http://www.youtube.com/v/RBAOkZTbvGM?version=3&amp[/flash:2a6ahgcy]
      Visit program web-site for more info.
      Terms and Definitions
      Duration of Insolation at a given point is the time period while direct sunlight reaches the test point.
      Insolation is the solar radiation that reaches the earth's surface. It is measured by the amount of solar energy received per square centimetre per minute. (Note, that Chronolux does not calculate insolation, but only its duration).
      SVF (sky view factor) is the extent of sky observed from a point as a proportion of the total possible sky hemisphere. (A Dictionary of Earth Sciences | 1999 | AILSA ALLABY and MICHAEL ALLABY).
      WVF (window view factor) is the extent of sky observed from a point as a proportion of the total possibly observable sky from a point through a window (despite of shadowing objects outside the window).
      ver 1.0 beta 1
      fixes
      • resource file (chronolux.strings) has a proper syntax now
      • some patches were added in code to avoid encoding issues in localized versions
      ver 1.1 beta
      New features:
      • Interactive Resize Tool
      • Pick Test Surface Tool
      • Pick Window Face Tool
      Updates:
      • Global Settings dialog
      • Time Settings dialog
      Fixes:
      • Refresh command works properly even if test points were added inside a group
      • Report maker generates report without duplicating information about SVF and WVF
      ver. 1.1 video
      [flash=640,360:2a6ahgcy]http://www.youtube.com/v/b7gfkdtlkxQ?version=3&amp[/flash:2a6ahgcy]
      • W
        watkins
        Dear Kirill,
        The video link doesn't seem to be working when viewed here, but works if you go to your website.
        This looks to be a very useful plugin for building design and the positioning of renewable energy systems. I will watch its development with interest.
        Thank you for all your hard work.
        Kind regards,
        Bob
        • Didier BurD
          Didier Bur
          ThaaaaAAAAAAAnnnnnNNNNk You ! ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
          DB
          • T
            toto ete
            โ˜€ thanks kirill ๐Ÿ‘
            โ˜€
            • mitcorbM
              mitcorb
              Hi, kirill:
              Long time, no see ๐Ÿ˜„
                Fiat lux! ๐Ÿ˜Ž
                • mitcorbM
                  mitcorb
                  Hi, Pilou:
                  Long time, no see you, either. ๐Ÿ’š
                    @Mitcorb
                    I have made some translations for the French Section ! ๐Ÿ’š
                    Next will be the "Doh Tread"!
                    In French "Aaaaaaaaaahhhh bon sang, mais c'est bien sรปr!" ๐Ÿ˜„ (not yet started : sure next week! ๐Ÿ˜ณ
                    • K
                      kirill2008
                      Hi to all! Thanks for kind words! It's so great to be here again! ๐Ÿ‘ ๐Ÿ˜„
                      Did anyone try to install? Or demo video is the only reason to thank at the moment ๐Ÿ˜„
                      I use free installer for Windows programs Inno Setup. It works well on my laptop ๐Ÿ‘ I'm going to test it tomorrow at work as well (yes, the whole thing is not tested yet too...).
                      • N
                        notareal
                        Wow! Welcome back, kirill!
                        • boofredlayB
                          boofredlay
                          All I get is "Invalid Parameters" when trying to view the video.
                            I edited his video tag so it now works ๐Ÿ˜‰
                            • boofredlayB
                              boofredlay
                              Cheers TIG. ๐Ÿ‘
                              • bazB
                                baz
                                'SVF and Insolation'.
                                I would like to learn more about this, I've done a google on the terms above but I can't find out what they mean, any pointers?
                                Ta, baz
                                • P
                                  Panga
                                  Awesome tools !! Thanks a lot!!
                                  • PixeroP
                                    Pixero
                                    Is there any way it can take transparent materials in account?
                                    In my tests it acts as if a glass surface is opac.
                                    • K
                                      kirill2008
                                      Yes it is possible. It's necessary to set "Handle transparency" flag in "Global Settings" dialog to "Yes". It is also necessary to pay attention to "Transparency threshold" value.
                                      !["Handle transparency" flag in "Global Settings" dialog.](/uploads/imported_attachments/LgeC_handletransp.png ""Handle transparency" flag in "Global Settings" dialog.")
                                      This flag is set to "No" by default because it takes a little bit more time to handle transparency so when it's set to "Yes" it slows down script processing.
                                      • EdsonE
                                        Edson
                                        have you tested it on mac? perhaps all one has todo for it to run on mac is to perform a manual installation. if this is the case, could you please instruct us on how to make a manual installation? should I place the whole thing in my plugins folder?
                                        edson mahfuz, architect| porto alegre โ€ข brasil
                                        http://www.mahfuz.arq.br
                                          driven
                                          NO...
                                          the manual installation requires placing different folders in different locations.
                                          the 'Help' button in tools won't work from inside SU so I suggest you 'first' open the 'Help Pages' in safari to check if you want to instal it.
                                          to do this 'unzip' Chronolux 1_0 beta.zip and you'll have a new folder Chronolux 1_0 beta,
                                          follow the path to Chronolux 1_0 beta/Resources/en-US/chronolux/index.html and double click to open in Safari.
                                          If you still want to instal manually he's a pic of the paths...
                                          the main files go here
                                          Support files go here
                                          I haven't tested the whole thing yet, but you do need to turn on the toolbar in 'View' >> 'Tool Palates'
                                          • EdsonE
                                            Edson
                                            thanks, john. it seems easy enough o install. I will give it a try soon.
