    [Plugin] CleanUp
    974 Posts 217 Posters 860.8k Views 217 Watching
      AcesHigh
      @thomthom said:
      @aceshigh said:
      @thomthom said:
      @aceshigh said:
      why arent these coplanar faces (from two different GoogleEarth imported meshes) merged?
      Can you post the model?
      Also, what are your settings? Remember that CleanUp has options to take into account face normals, material and UV mapping when merging.
      Also, that image seem to illustrate faces occupying the same plane...?
      no need to upload the model. It happens with any model, when importing several GoogleEarth meshes which overlap.
      Well, I don't see the behaviour, so if I am to check this out I need something to work with.
      sorry ThomThom, it had happened in every experiment I did before, so I wrongly assumed it would happen in every one. But I did one try with two small pieces and nothing happened (although there were some lost textures in the process)
      So I will upload a SKP file. Thanks for the patience and hard work.
      And these meshes, do you merge them into one group?
      yup. Merge them into one group, then explode the meshes inside the group. Then CleanUp them. In the file I am sending you, not only some faces were lost when using CleanUp, as some coplanar faces were not merged, so you can see some texture flickering when rotating around.
      experimento2.skp
          That model is after CleanUp is run? You got the original?
            AcesHigh
            what settings ThomThom? The ones from CleanUpÂł?
            everything selected except Geometry to Layer 0, Merge Identical Materials (its two different materials, a bitmap for each imported mesh), so I saw no reason to use it) and Erase Stray Edges.
            sorry, I didnt keep the original imported meshes. But I will try again with new imported meshes.
              Looking at the one you sent, I selected everything and intersected it with itself a few times. CleanUp doesn't clean up faces that partially overlaps. Only faces that fully cover the exact same space as another. After intersecting and then cleaning there was no overlapping.
                AcesHigh
                here... I copied the two meshes and joined them in a group, exploded them, and used Cleanup. No lost triangles this time, but there are plenty of overlapping triangles. (sometimes they dont appear when viewing in the textured mode, but when you used SHADED mode you will see the overlapping triangles...)
                of course, the problem gets worse when you have to import even more mesh pieces, as sometimes you have over 3 meshes overlapping.
                experimento3.skp
                  AcesHigh
                  I will try that, thanks... however... how can I intersect if they are not solids?
                  ps: I am trying to solve, with CleanUp, about the same problem that made me ask for the "GoogleEarth Meshes boolean subtract" plugin at the topic http://forums.sketchucation.com/viewtopic.php?f=323&t=40555
                    Not intersecting with Solid Tools, but the regular intersect that's been in SU since, ever..? From the context menu, there is Intersect Faces menu item.
                      AcesHigh
                      since ever, but I had never seen or used it before 😆
                      anyway, however, intersected it with itself several times, and when I used cleanup³, several triangles were lost, and got some error messages 😱
                        What where the error message?
                          AcesHigh
                          something along these lines (not exactly the same because I had to test again, with new Earth imported meshes, so different triangles disappeared, etc)
                          Results of Validity Check.
                          CEdge (4234) and CEdge (7926) connect the same 2 vertices - fixed
                          The plane equation for CFace (4767) is not valid - fixed
                          35 errors occurred. Please report the error and sample model to the author.
                          35 - Face merge resulted in lost geometry!
                          • sumasterS Offline
                            sumaster
                            Dear Thomthom Sir,
                            here you are launch your new Cleanup (3.1.8) — 06 October 2011
                            ‱ Whats new features you are added ❓
                            and one problem can you solve in new version
                            I'm architectural student and import CAD drawing and lock that drawing in sketchup viewport
                            but when i play / start " Clean With Last Setting " he also cleanup viewport with lock group/component 😼
                            See here ......
                            Regular selection
                            Lock selection
                            Finally clean every thing .....
                            And thank you for this tool its very best for me or ever one ...... 😄 😉
                            I'm very happy with this tool ......
                            Thank you,
                            SUmaster
                              The way CleanUp traverses the model it's tricky to know what is part of a locked group or not. But I'll put it down for investigation.
                              • sumasterS Offline
                                sumaster
                                Yes thank you .....
                                Thank you,
                                SUmaster
                                • dereiD Offline
                                  derei
                                  You can use ruby to check if is locked or not
                                  http://code.google.com/apis/sketchup/docs/ourdoc/group.html#locked?
                                  http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#locked?
                                  DESIGNER AND ARTIST DEREI.UK
                                    I know, but, I traverse the model by model.definitions.each - which means that I do not know if the parent for the instances I traverse are locked. I could be checking a sub-group of a locked group and .locked? will return false.
                                      Tahesco
                                      Hi ThomThom,
                                      We imported a 100mb model from ARCHICAD into SU (in fbx format). This goes slow but it works.
                                      The problem is the same material gives different uvw_sizes on my components. The same brick material is 1 cm on a component while it's neigbour component has bricks of 20 cm ?!?.
                                      Is there a way to reset all components to the same scale, so my bricks are uniform on all objects/ components? (like reset xform in 3dsmax)
                                      Thanks for all the usefull work!
                                      TTion
                                      • bagateloB Offline
                                        bagatelo
                                        Another thing to do would be also interesting can recursively set all groups and components to "scale definition."
                                        @tahesco said:
                                        Hi ThomThom,
                                        TTion
                                          And how would you handle scenarios where one definition has instances of different scale... ?
                                            Tahesco
                                            In my case I don't care if I loose all instances. All scene objects may become true default geometry. (because my scene objects are build in ARCHICAD).
                                            Thanks again,.
                                            NB -> Maybe an object replacer-script is capable of repairing killed Insances in a SU scene,...
                                            • 11
                                            • 12
                                            • 13
                                            • 48
                                            • 49
                                            • 11 / 49
