    SU 9 Wishlist
    436 Posts 99 Posters 85.8k Views 99 Watching
    • O Offline
      otb designworks
      or how, if you have a doc minimized on the dock and half the time, when you bring it back up to work on, all of the inference points are giant white squares.
      And one of my biggest pet peeves is I hate, and I truly, hate, that the move tool can rotate, too. How many times does it try to default to rotate when I never rotate with the move tool, and I have to zoom in to get it to revert, and then zoom back out to see where I am moving it. Time waster and it happens quite often.
      Or, when locking the inference direction by holding down the shift key, it is impossible to rotate with the middle mouse button, as it defaults to panning. Why can't the inference lock work like a toggle ( a la making multiple copies with the option key)? So, worflow would be: move object in prefered axis, hit shift once to lock, hold down middle mouse button, rotate to desired view, and because the mouse button is down, holding down shift would still pan without releasing the axis lock, place object from new view. I know I am being juvenile and I could just change my axis lock hotkey, but I really like using shift, and have for 7 years, so please humor me πŸ’š
      Cheers, Chuck
      OTB Designworks is on Youtube
        @Chuck
        Does the arrow keys not lock an inference on Macs?
        • O Offline
          otb designworks
          @Chuck
          I use the arrow keys for my front, sides, and back elevation views; also vestiges of an early SU user, you know?
          Cheers, Chuck
          • pbacotP Offline
            Utiler
            I am with you on the layers. Users have been trying to get our CAD developer to do this sort of things for years. We have "sheets" that can save combinations of layers and save layer presets, but they are not nested or related in any way. In large files navigating the layers can be quite a task, because the "structure" must be kept in your head to some extent. It should be one-click or very fast to go to a layer grouping in the hierarchy. One thing that annoys me in my CAD is "sheets" is accessed only in pull-down menus whereas switching sheets, in a developed file, needs to be as fast as any navigation action.
            With the ability to Trim solids now you could insert that window component into the wall and the negative solid would trim the wall to create an opening.
            This reminds of a process I am experimenting on making solid wall elements for creating house models with standard features.It is OT so please see http://forums.sketchucation.com/viewtopic.php?f=15&t=40565&p=359153#p359153 if you want.
            • O Offline
              otb designworks
              And I wish that when I open a recent doc from the recent file dropdown, and then save as, it defaults to the location of the last document I opened with the open file dropdown, and not the one that I just opened. Wastes a lot of time navigating file structures to where I need to save as to.
              Cheers, Chuck
              • pbacotP Offline
                And I don't like how SU, on MAC, starts up with a new document and then I have a new document window open until I close it.
                This should be normal Mac behavior when first launching. However it is NOT like other apps when SU is already open and you go to SU (using the dock, for instance) and a new default file opens. THAT I find annoying.
                Also unlike other Mac apps. It always asks to save when closing the new default file--when I have done nothing at all yet.
                • pbacotP Offline
                  I wonder if this is a SU or MacOS thing. Do you find other apps act differently?
                  • jgbJ Offline
                    jgb
                    So, how crazy is it that the windows version can only have one model open at a time?! That must drive you guys batty.
                    If you have enough RAM you can open 2 or 3 sessions of SU, not separate windows. You can transfer objects via the clipboard not drag&drop. Just make sure you open the 2nd session before you copy to the CB or you may lose it.
                    jgb
                      I think that is more of an graphic card issue. I can have many SU windows open. No prob. nVidia Geforce 8800 GT and Quadro 3800. But I've used SU on some lower spec cards, integrated etc, and they quickly fail.
                      • Chris FullmerC Offline
                        Same, I've never run into issues opening many many SU model at the same time.
                        • jgbJ Offline
                          jgb
                          I've once had 3 SU sessions open on my old ATI card with 512k, but it was slow to d/l the clipboard or pan. Mind you, they were all big files that had common comps, before I discovered my comp. Library.
                          However using the comp lib is not as good as copy then paste in place which I usually need when co-ordinated placements between models. My models tend to get big fast so I split a model along logical layers. Accurate placement is paramount for common parts between files.
                          2 sessions were about normal response.
                          I have only had 2 open on my new NVIDIA card with 1gb and it was normal speed as if 1 session.
                          jgb
                          • I Offline
                            i4-design solutions
                            I do a lot of modelling for a large global retailer which tends to cover interior images and walkthroughs of superstores. What i would love to see SketchUp offer is the ability to export a flat mesh of my models (such as retail cabinets) to PhotoShop or something that i can paint a realistic texture to rather than rely upon third party render packages. These are fine for stills but no so for interactive walkthroughs where my clients PC's might not be as powerful.
                            • brodieB Offline
                              brodie
                              You're talking about exporting a 3d model and then texturing it in PS? PS can already open .3ds, .dae, .kmz, and .obj files all of which SU can export. What else would you want?
                              -Brodie
                              • I Offline
                                i4-design solutions
                                Thanks for the reply. I will give it a try and see what happens. With these exports, are you suggesting i can insert a 3D model to PS? or do i have to export 2D images? Sorry but if I can get this process improved it will obviously benefit a number of my walkthroughs.
                                • brodieB Offline
                                  brodie
                                  Well if you have PS Extended you can infact bring 3d models into it and do texturing work there. To be honest I have the extended version but I've never used this feature. I've found it a bit awkward and I don't know of anyone else who uses it so I've not put any time into it. I can't really advice on what you should do because I'm unclear on what you're trying to achieve. You're doing SU walkthroughs but you aren't satisfied with your textures? You'll always have some limitations unless you do a rendered walkthrough but if you think you can achieve what you want simply by editing textures I'd just right click the texture go to Texture -> Edit Texture Image and you can tweak there. But I may be misunderstanding what you want to do?
                                  -Brodie
                                    Anton_S
                                    I want sketchup text options(like font, size, type), to be also included in sketchup api, so we could style-up our plugins. Agree? πŸ‘
                                    Here are the two texts that are wanted to be updated:
                                    Sketchup.active_model.add_note and Sketchup.active_model.entities.add_text
                                    • O Offline
                                      obkcaptain
                                      My wish list for the future (?) SU9
                                      I can imagine all was asked....
                                      But it would be interesting "coupling" tools.
                                      Imagine: rotate and translate when copying, push-pull following curves, move P-r-e-ci-s-e-l-y any object without to be insane and export only the "camera window"
                                      And...don't forget render !!!
                                      Cheers
                                      • brodieB Offline
                                        brodie
                                        What is that?
                                        What do you mean?
                                        Like the Joint Push Pull plugin?
                                        like moving an object in the direction you want to go and typing 1.32"?
                                        What does it export now?
                                        Could be interesting in the Pro version. It'd be neat to see how SU would handle something as complex as rendering.
                                        -Brodie
                                        • O Offline
                                          obkcaptain
                                          What is that?
                                          Waht you read. Working with two tools together
                                          What do you mean?
                                          Can you rotate and traslate at the same time?
                                          Yes except if you are using "hand curves"
                                          No. I'm refering moving any object selecting ONLY origing point and destination point.
                                          Yes and not. When exporting, certainly it export what you see. BUT it export also what you can't see. Imagine a block of apartments with 24 floors and you REALLY need renderize only 3 or 4...
                                          Or integrating a render engine INSIDE...
                                          -Brodie
                                          • brodieB Offline
                                            brodie
                                            I'm still not understanding I guess. It seems like SU does that a lot. The move tool for instance also rotates, copies, creates arrays, and stretches geometry.
                                            What do you mean by translate? Move? You can use the rotate tool and set the origin somewhere other than on the object which will rotate the object at the same time it's moving it about a circle centered on the tool's origin. This is how you make polar arrays of course. Or you can use the move tool to move an object and then while still in the tool you can rotate the object. I guess that's not 'at the same time' but I'm not sure how you'd control all those variables at once. Is there another software that does what you're referring to?
                                            I don't know what a 'hand curve' is
                                            Select object, type M for move tool, click origin point, click destination point. That's currently how it works. Again, I must be misunderstanding.
                                            Then you'd hide those other floors or put them on a layer and turn that layer off. Again, this functionality is already within SU. You say that it exports what you see but also what you CAN'T see. It sounds like you want to reverse that so that it would export what you can't see instead of what you can see which seems counterintuitive.
                                            -Brodie
                                            • 11
                                            • 12
                                            • 13
                                            • 21
                                            • 22
                                            • 11 / 22
