    [Plugin] QuadFaceTools
    680 Posts 116 Posters 699.2k Views 116 Watching
      Version 0.4.0
      Important!
      This version redefines what a QuadFace is. In order to use quad face meshes used by older versions you must update them.
      Tools > QuadFace Tools > Convert > Sandbox Quads to QuadFace Quads
      Download
      Changelog 0.4.0
      UV Mapping
      [flash=560,315:23wd2kgt]http://www.youtube.com/v/HdX517AryWs?version=3&hl=en_US[/flash:23wd2kgt]
      UV Transferring
      [flash=560,315:23wd2kgt]http://www.youtube.com/v/qQHsabwvErg?version=3&hl=en_US[/flash:23wd2kgt]
      UV Unwrap
      [flash=560,315:23wd2kgt]http://www.youtube.com/v/hnW_yjkM_SY?version=3&hl=en_US[/flash:23wd2kgt]
        That is immense.
        I commend your hard work and perseverance πŸ‘
        • dereiD Offline
          derei
          As I recall, you have (at least) two more plugins that do some related stuff. Does it replace any of them? I'm asking to know if I should remove something from what I already have.
          Thank you for this one.
          DESIGNER AND ARTIST DEREI.UK
            Is a portion of the UV Toolkit 2 tools now redundant?
              Thanks thomthom πŸ˜„
              I've also updated and posted my 'EEbyRails' and 'EEbyLoft' tools today so that their new 'Quad Face' options follow the latest standards, where diagonals are soft+smooth+hidden...
                Yea, parts of the features in UV Toolkit is now in QuadFace. And the mapping tool I promised for UV Toolkit is now implemented in QuadFace Tools, because I found that mapping required a predictable topology.
                UV Toolkit is not 100% obsolete yet, but it might slowly become so. I don't expect I'll add more to UV Toolkit, instead QuadFace Tools will get the new features.
                However, I now plan to take a break from QuadFace Tools ( final last words... ) while I return focus on Vertex Tools and Bezier Surface. (Both which will benefit from many of the features in QuadFace Tools.)
                  Wow! That was fast! πŸ‘ πŸ‘
                    Sensational, TT. Now I can make my Arch texturing tutorial #3! 😍
                      Looking forward to it!
                        jorge2011
                        thank you very much for this excellent update. is excellent.
                        unfortunately I have a problem:). sketchup generates the following error:
                        Error al cargar archivo C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb
                        undefined method to_l' for nil:NilClassError al cargar archivo tt_quadface.rb undefined method to_l' for nil:NilClass
                        how I can fix this?
                          how I can fix this?
                          When do you get this error?
                            jorge2011
                            when I start sketchup
                              What version of TT_Lib2 do you have?
                                jorge2011
                                the last version
                                  jorge2011
                                  is odd. install this plugin yesterday and worked well.
                                  Today I went back to start and generated that error sketchup
                                    @jorge2011 said:
                                    the last version
                                    Can you check exactly what version you have to be sure? Type TT::Lib::VERSION into the Ruby Console. I just want to make sure as I've had cases before where users thought they had the latest, but turned out that they didn't.
                                    Does it give you that error every time?
                                    If so, after you started SU, can you open the Ruby Console and type: load 'tt_quadface.rb' and post back any errors if there is any.
                                      jorge2011
                                      TT::Lib::VERSION 2.5.8
                                      When I write load 'tt_quadface.rb' , ruby console generates the following message:
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:20: warning: already initialized constant PLUGIN
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:21: warning: already initialized constant PLUGIN_ID
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:22: warning: already initialized constant PLUGIN_NAME
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:24: warning: already initialized constant PLUGIN_VERSION
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:27: warning: already initialized constant PATH_ROOT
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:28: warning: already initialized constant PATH
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:29: warning: already initialized constant PATH_ICONS
                                      Error: #<NoMethodError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_Lib2/settings.rb:51:in []': undefined method to_l' for nil:NilClass>
                                      (eval)
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_Lib2/settings.rb:90:in set_default' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb:45 C:/Archivos de programa/Google/Google SketchUp 8/Tools/extensions.rb:36:in require'
                                      C:/Archivos de programa/Google/Google SketchUp 8/Tools/extensions.rb:36:in load' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:41:in register_extension'
                                      (eval):0:in `load'
                                      (eval):0
                                      I use
                                      Sketchup 8 in Spanish y windows xp sp3
                                        jorge2011
                                        thom thank you very much for your time.
                                        but.
                                        re-install the program sketchup, and now the plugin works fine. I can not have that problem occurred but works fine
                                        πŸ˜„ thank
                                          It works? Good - glad it does.
                                          That last error you posted guides me to where to look. I'll look at the code and see what I can do to avoid it.
                                          • N Offline
                                            notareal
                                            @thomthom said:
                                            Version 0.4.0
                                            Important!
                                            Stunning... You have done amazing work. I hope this will inspire others too. Thank you!
                                            • 33
                                            • 34
                                            • 4 / 34
