    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.1k Views 107 Watching
      alexdobras
      a very big thanks for the plugin!
        costa
        a very very good plug-in,. thank you and congratulations
          angel3wijaya
          Thank you very much!
          but its tools not work on my mac.... 😒
            angel3wijaya
            Thank you very much
              millzye71
              Very good plug in indeed!!! Could this be modified so that you could use these steel sections as rafters, and be able to rotate them at a degree up or down on the axis that you have drawn. This would be great when modelling steel frames.
              Cheers
              Millzye
                adiwinardi
                thanks for sharing, this is very helpful. I'm sure the people of Japan will be stronger for the future...
                adi
                indonesia
                  tak2hata
                  I corrected this script.
                  The version changes to 0.3.
                  A very huge earthquake hit Japan. 2011.3.11.
                  This script was exhibited for that encouragement.
                  And Japan is becoming fine gradually, thanks to your aid.
                  Thank you very much.
                  by TAK2HATA
                    mwm5053
                    Great plugin, Thanks 🎉 needed this for a contractor that builds steel buildings. Maybe some sort of corrugated sheet metal for walls 🎉 plezzzzz.
                    Will make a donation to children of Japan
                    2011 iMac
                    SU 2015 Pro, 2017 Make
                    V2 Twilight
                    macOS Sierra 10.12.5
                    • EdsonE Offline
                      Edson
                      try the metal deck feature in 1001bit pro:
                      http://www.mahfuz.arq.br
                      • 66searcher6 Offline
                        66searcher
                        well done!
                        http://hamidtoliat.deviantart.com/
                          tak2hata
                          Hi ,mwm5053 and Edson.
                          [attachment=0:3rim4p6a]<!-- ia0 -->1001pro.png<!-- ia0 -->[/attachment:3rim4p6a]
                          I updated BST version to v0.4.
                          Using "[SHAPE]" for header of profile name.and the skp filename after that.
                          The skp file for profile must saved in the foleder "plugins¥building_structure_tool¥shapes".
                          See the animation about addin new profile.
                          But I think 1001 bit pro is better,because the openning to wall like sheet metal wall is difficult on my tool.
                          please try them.
                          thanks.
                          by TAK2HATA
                            ptsdr
                            Excellent Thk for Post
                              raymond
                              Can't download it.But it looks good... 😞
                                Raymond, you should be able to download it. What's the problem?
                                Note in order for the board to work properly, you need to allow browser cookies.
                                  tak2hata
                                  Hi,raymond and gaieus and all.
                                  I update this plugin to v0.5 in Nov13.2011.
                                  Raymond..
                                  I will upload on my webpage.(Now still uploaded older version)
                                  Visit there If you do not able to download here.
                                  by TAK2HATA
                                    raymond
                                    Thanks a lot.
                                      lukestar
                                      hi,
                                      where do you download the Building Structures Tool from???
                                        In the first post of the thread. 😒
                                        Before you download it, read at least that entire post.
                                          lukestar
                                          The Building Structure Tool does not load properly. I go to WEBDIALOG and I do not get any icons???
                                          What's the GO?
                                          Lukestar
                                            tak2hata
                                            @lukestar said:
                                            What's the GO?
                                            Lukestar
                                            Hi lukesatr.
                                            I'm sorry.I see that on mac.
                                            I will recover it to work on mac.
                                            Please wait.
                                            I update files.
                                            It will show webdialog with icons on mac.
                                            But can not restore size of webdialog.
                                            I will improve it.
                                            Thanks.
                                            by TAK2HATA
                                            • 16
                                            • 17
                                            • 2 / 17
