    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • C
      costa
      a very very good plug-in,. thank you and congratulations
        angel3wijaya
        Thank you very much!
        but its tools not work on my mac.... 😒
          angel3wijaya
          Thank you very much
            millzye71
            Very good plug in indeed!!! Could this be modified so that you could use these steel sections as rafters, and be able to rotate them at a degree up or down on the axis that you have drawn. This would be great when modelling steel frames.
            Cheers
            Millzye
              adiwinardi
              thanks for sharing, this is very helpful. I'm sure the people of Japan will be stronger for the future...
              adi
              indonesia
              • T
                tak2hata
                I corrected this script.
                The version changes to 0.3.
                A very huge earthquake hit Japan. 2011.3.11.
                This script was exhibited for that encouragement.
                And Japan is becoming fine gradually, thanks to your aid.
                Thank you very much.
                by TAK2HATA
                  mwm5053
                  Great plugin, Thanks 🎉 needed this for a contractor that builds steel buildings. Maybe some sort of corrugated sheet metal for walls 🎉 plezzzzz.
                  Will make a donation to children of Japan
                  2011 iMac
                  SU 2015 Pro, 2017 Make
                  V2 Twilight
                  macOS Sierra 10.12.5
                  • EdsonE
                    Edson
                    try the metal deck feature in 1001bit pro:
                    http://www.mahfuz.arq.br
                    • 66searcher6
                      66searcher
                      well done!
                      http://hamidtoliat.deviantart.com/
                      • T
                        tak2hata
                        Hi ,mwm5053 and Edson.
                        [attachment=0:3rim4p6a]<!-- ia0 -->1001pro.png<!-- ia0 -->[/attachment:3rim4p6a]
                        I updated BST version to v0.4.
                        Using "[SHAPE]" for header of profile name.and the skp filename after that.
                        The skp file for profile must saved in the foleder "plugins¥building_structure_tool¥shapes".
                        See the animation about addin new profile.
                        But I think 1001 bit pro is better,because the openning to wall like sheet metal wall is difficult on my tool.
                        please try them.
                        thanks.
                        by TAK2HATA
                        • P
                          ptsdr
                          Excellent Thk for Post
                            raymond
                            Can't download it.But it looks good... 😞
                            • GaieusG
                              Raymond, you should be able to download it. What's the problem?
                              Note in order for the board to work properly, you need to allow browser cookies.
                              • T
                                tak2hata
                                Hi,raymond and gaieus and all.
                                I update this plugin to v0.5 in Nov13.2011.
                                Raymond..
                                I will upload on my webpage.(Now still uploaded older version)
                                Visit there If you do not able to download here.
                                by TAK2HATA
                                  raymond
                                  Thanks a lot.
                                  • L
                                    lukestar
                                    hi,
                                    where do you download the Building Structures Tool from???
                                      In the first post of the thread. 😒
                                      Before you download it, read at least that entire post.
                                      • L
                                        lukestar
                                        The Building Structure Tool does not load properly. I go to WEBDIALOG and I do not get any icons???
                                        What's the GO?
                                        Lukestar
                                        • T
                                          tak2hata
                                          @lukestar said:
                                          What's the GO?
                                          Lukestar
                                          Hi lukesatr.
                                          I'm sorry.I see that on mac.
                                          I will recover it to work on mac.
                                          Please wait.
                                          I update files.
                                          It will show webdialog with icons on mac.
                                          But can not restore size of webdialog.
                                          I will improve it.
                                          Thanks.
                                          by TAK2HATA
                                          • L
                                            lukestar
                                            I cannot get this Pluggin to work in that there are no tools displayed. I have to install it again, but the same result. Yes went to WEBDIALOG to load the tools but I get a blank panel.
                                            Help?
                                            Luke
                                            • 16
                                            • 17
                                            • 4 / 17
