    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • U
      Uguzzone
      I just made the donation for save the children for japan.
      Thanks for the plugin
      • GaieusG
        • tibetT
          tibet
          hi guys,
          from some odd reason i can´t recover BST icons.
          any idea how to fix it please?
          i reinstalled it again without success.
          maybe, i miss something, because everything seems to be fine.
          thanks!
          http://i52.tinypic.com/6pw36v.jpg
          SU 2015 Pro on Win10 x64
          • G
            glro
            [quote="tak2hata"]Building structure tool for Sketchup
            Draw Structures and Modify Easy.
            v0.2--solved probrem about reading default first time by TIG.Thanks.
            [attachment=0:1inpg13m]<!-- ia0 -->building_structure_tool.zip<!-- ia0 -->[/attachment:1inpg13m]
            very efficient
            a limitation, though, that makes it useless when you have to draw steel beams that are not parallel to the global axis
            changing to a provisional axis system doesn't help
            in addition to girder, beam, column, which a re horizontal or vertical, ... would it be possible to draw a structural member in any direction?
              alexdobras
              a very big thanks for the plugin!
              • C
                costa
                a very very good plug-in,. thank you and congratulations
                  angel3wijaya
                  Thank you very much!
                  but its tools not work on my mac.... 😒
                    angel3wijaya
                    Thank you very much
                      millzye71
                      Very good plug in indeed!!! Could this be modified so that you could use these steel sections as rafters, and be able to rotate them at a degree up or down on the axis that you have drawn. This would be great when modelling steel frames.
                      Cheers
                      Millzye
                        adiwinardi
                        thanks for sharing, this is very helpful. I'm sure the people of Japan will be stronger for the future...
                        adi
                        indonesia
                        • T
                          tak2hata
                          I corrected this script.
                          The version changes to 0.3.
                          A very huge earthquake hit Japan. 2011.3.11.
                          This script was exhibited for that encouragement.
                          And Japan is becoming fine gradually, thanks to your aid.
                          Thank you very much.
                          by TAK2HATA
                            mwm5053
                            Great plugin, Thanks 🎉 needed this for a contractor that builds steel buildings. Maybe some sort of corrugated sheet metal for walls 🎉 plezzzzz.
                            Will make a donation to children of Japan
                            2011 iMac
                            SU 2015 Pro, 2017 Make
                            V2 Twilight
                            macOS Sierra 10.12.5
                            • EdsonE
                              Edson
                              try the metal deck feature in 1001bit pro:
                              http://www.mahfuz.arq.br
                              • 66searcher6
                                66searcher
                                well done!
                                http://hamidtoliat.deviantart.com/
                                • T
                                  tak2hata
                                  Hi ,mwm5053 and Edson.
                                  [attachment=0:3rim4p6a]<!-- ia0 -->1001pro.png<!-- ia0 -->[/attachment:3rim4p6a]
                                  I updated BST version to v0.4.
                                  Using "[SHAPE]" for header of profile name.and the skp filename after that.
                                  The skp file for profile must saved in the foleder "plugins¥building_structure_tool¥shapes".
                                  See the animation about addin new profile.
                                  But I think 1001 bit pro is better,because the openning to wall like sheet metal wall is difficult on my tool.
                                  please try them.
                                  thanks.
                                  by TAK2HATA
                                  • P
                                    ptsdr
                                    Excellent Thk for Post
                                      raymond
                                      Can't download it.But it looks good... 😞
                                      • GaieusG
                                        Raymond, you should be able to download it. What's the problem?
                                        Note in order for the board to work properly, you need to allow browser cookies.
                                        • T
                                          tak2hata
                                          Hi,raymond and gaieus and all.
                                          I update this plugin to v0.5 in Nov13.2011.
                                          Raymond..
                                          I will upload on my webpage.(Now still uploaded older version)
                                          Visit there If you do not able to download here.
                                          by TAK2HATA
                                            raymond
                                            Thanks a lot.
                                            • 16
                                            • 17
                                            • 3 / 17
