    Soften-Edges using by ruby
    23 Posts 7 Posters 4.8k Views 7 Watching
      Jim
      I don't think it is available through an API method; you will need to write your own soften method.
        Andreas
        @jim said:
        ... you will need to write your own soften method.
        How does it work? Do you have an idea?
        With best regards from Germany
        Andreas
          Compare the angle_between of the face's normal, soft and smooth if they are within the threshold.
            Make an array of the selected edges [or of the edges within selected groups etc].
            Iterate through those edges and test it they have >1 face.
            Soft/Smooth them...
            def makesoftsmooth()
             model=Sketchup.active_model
             ss=model.selection
             ### You can assemble any collection of edges
             ### Here it's from the model's current selection
             edges=[]
             ss.to_a.each{|e|
               edges << e if e.class==Sketchup;;Edge
               e.entities.each{|ee|edges << ee if e.class==Sketchup;;Edge}if e.class==Sketchup;;Group
             edges.each{|edge|
               if edge.faces[1]
                 edge.soft=true
                 edge.smooth=true
            end#def
            Save code as makesoftsmooth.rb or use the def as part of a broader tool.
            Execute it as makesoftsmooth()
            This softens ALL edges that have at least 2 faces - but if you want to soften edges based on angle between its two faces use something like ang=edge.faces[0].normal.angle_between(edge.faces[1].normal) and then use edge.soft=true if ang.radians >= 45.0 etc or whatever the angle you desire [here it's 45 degrees]
              Andreas
              Soft/Smooth them...
              >  ss=model.selection
              >  edges=[]
              >  ss.to_a.each{|e|
              >  edges.each{|edge|
              >    if edge.faces[1]
              >      edge.soft=true
              >      edge.smooth=true
              >    end
              > end#def
              Thank you!
              That works well, if the edges not in a group.
              But on edges in a group it doesn´t work.
              What should I do so that it acts on the edges in a group?
              Andreas
                The native soft+smooth tool doesn't soft+smooth any edges that is connected to more or less than 2 faces.
                  OK just adjust the code so that it's a edge.faces[1] and not edge.faces[2] test...***
                  To work on a group's edges
                  ###... add this into the mix...
                  groups=[]
                  ss.to_a.each{|e|groups << e if e.class==Sketchup;;Group}
                  groups.each{|group|
                    group.entities.to_a.each{|e|
                      if e.class==Sketchup;;Edge and e.faces.length==2 ###***
                        e.soft=true
                        e.smooth=true
                      end#if
                    baldaman
                    Dear TIG, I tried to edit you code in order to be able to choose the smooth angle but I didn't succeed.
                    WHat am I doing wrong?
                    def ss()
                    ss=model.selection
                    edges=[]
                    ss.to_a.each{|e|
                    edges.each{|edge|
                       if edge.faces[1]
                         edge.smooth=true if ang.radians >= 45.0
                    end#def
                      I haven't tested it but it looks OK - except I'd have used
                      edge.soft=true if ang >= 45.degrees edge.smooth=true if ang >= 45.degrees
                      rather than
                      edge.soft=true if ang.radians >= 45.0 edge.smooth=true if ang.radians >= 45.0
                      There's a type in the group part use ee NOT e...
                      e.entities.each{|ee|edges << ee if **ee**.class==Sketchup::Edge}if e.class==Sketchup::Group
                      But but ought to work ?
                      If you get it to 'puts' edges and ang.radians etc as it iterates through what is shown in the Ruby Console ??
                        baldaman
                        Here is the code and the result,
                        I tried with different angles.
                        If I choose 90° nothing is smoothed neither soften.
                          baldaman
                          Oups, here is the code
                          def ss()
                          ss=model.selection
                          edges=[]
                          ss.to_a.each{|e|
                             e.entities.each{|ee|edges << ee if ee.class==Sketchup;;Edge}if e.class==Sketchup;;Group
                          edges.each{|edge|
                             if edge.faces[1]
                          end#def
                            The angle between adjacent faces on the cylinder's curve is 360/numsegs = 15 degrees for 24 segements so that is less than 45 degrees so they won't be smoothed !
                            I suspect you want to smooth edges that are NOT >= 45.degrees - so reverse the logic of the test to
                            edge.soft=true if ang < 45.degrees edge.smooth=true if ang < 45.degrees
                            and then 'sharp' edges will be kept 'solid' but edges with faces with similar normals will get smoothed
                            So a right-angle arris stays sharp and a nearly flat surface gets smoothed...
                              baldaman
                              ... I am soooo stupid!
                              Thank you very much, it works perfectly.
                              Thank you very much master TIG
                                That's OK 😉
                                I should have spotted the error in your logic earlier too 😮
                                • artmusicstudioA Offline
                                  artmusicstudio
                                  hello,
                                  this piece of code is very helpful.
                                  in my case this works:
                                  SMOOTH LEFT
                                  ss=group20.entities
                                  edges=[]
                                  ss.to_a.each{|e|
                                  edges << e if e.class==Sketchup::Edge
                                  e.entities.each{|ee|edges << ee if e.class==Sketchup::Edge}if e.class==Sketchup::Group
                                  edges.each{|edge|
                                  if edge.faces[1]
                                  edge.soft=true
                                  edge.smooth=true
                                  BUT THIS ONE (smoothing with angle limit)
                                  ss=group20.entities
                                  edges=[]
                                  ss.to_a.each{|e|
                                  e.entities.each{|ee|edges << ee if ee.class==Sketchup::Edge}if e.class==Sketchup::Group
                                  edges.each{|edge|
                                  if edge.faces[1]
                                  is quit by following:
                                  VAR. 0.1 k
                                  load '01.rb'
                                  Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1516:in draw_stairs'
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1515:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1515:in draw_stairs'
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:973:in `each'
                                  any idea about the "normal" problem?
                                  thanx stan
                                    Recast:
                                    edges.each{|edge|
                                    if edge.faces[1]
                                    as
                                    edges.each{|edge|
                                    if edge.faces[1]
                                    because in YOUR version you are trying to get the normal of ALL edge's faces even if an edge doesn't have any faces ! Or if the face only has one face YOUR version fails when it can't find the normal of the non-existent second face !
                                      artmusicstudio
                                      YEAP!
                                      smooth like a sup of tea with milk on a sunny afternon......
                                      smoothing works perfect , thanx a lot ("again what learned", as we say here in bavaria)
                                      lost a ot of time today with fighting again coordinate systems, whatever i do, the elements don't place themselves sometimes , where i expect them to, it seems, that within groups and components the time & space works different sometimes.....
                                      stan
                                        glro
                                        > groups=[]
                                        > groups.each{|group|
                                        >       e.soft=true
                                        >       e.smooth=true
                                        >     end#if
                                        it works for groups, but not for components...
                                        is it possible?
                                          Assuming ss=Sketchup.active_model.selection...
                                          defns=[]
                                          ss.grep(Sketchup;;ComponentInstance).each{|e|defns << e.definition}
                                          defns.uniq!
                                          defns.each{|defn|
                                            defn.entities.grep(Sketchup;;Edge).each{|e|
                                              if e.faces.length==2
                                                e.soft=true
                                                e.smooth=true
                                          or something similar...
                                            glro
                                            defns=[]
                                            > defns.uniq!
                                            > defns.each{|defn|
                                            >       e.soft=true
                                            >       e.smooth=true
                                            >     end
                                            yes...it works
                                            this will save me time, since i noticed that some components edges come back visible in my models, for unknown reason...
                                            now with just one clic, the problem is solved
                                            thank you
