    Round Edges with Textures
    32 Posts 4 Posters 4.0k Views 4 Watching
      gelbuilding
      Unfortunately no, if i model in SU it looks great. Though when i use my modeling program Chief Architect it extremely difficult to achieve the same results.
        gelbuilding
        Here is the test model house. Have a close look at the mesh, notice how the stone doesnt match on the corners. πŸ’­
        Any suggestions?
          Could you attach the skp file, too? (And if you have, the Thea mat.pack file as well - rename it to zip to be able to attach)
            gelbuilding
            here is the SU file
            teststone.skp
              gelbuilding
              Thea pack file
              test_wall.pack.zip
                gelbuilding
                Very tedious to match up the stone with all the mesh.
                  gelbuilding
                  Larger scale stone for better view of corners
                    If you just 'chamfer' the corner and apply the materials, then use the eyedropper to sample one face's material and if needed then my Texture Tools to adjust the horizontal spacing of any abutting face's texture by a few mm at a time [shift=x10] - you get quickly get this...
                    The pattern matching will run out at a corner somewhere unless you tweak horizontal scaling carefully to match Capture.PNG
                      gelbuilding
                      The round edge plugg in is good.
                      The window looks good, except look at the right side of the door. I dont know how to fix.
                      Help please.
                        gelbuilding
                        Another view
                          There are serious problems with your model. Here are a bunch of things:
                          • all faces are triangulated. In SketchUp, this leads to unnecessarily large poly count, texturing as well as problems with plugins like Round corners.
                          • You have a layered wall with who knows how many layers inside (I am not talking about SketchUp layers but architectural layers). I know the model is coming from Chief Architect and represents the real building things but for simple visualization (where these inner faces cannot be seen) they are just extra stuff to deal with. "Only model what you will see" - this is visualization, not building documentation.
                          • Your wall pieces are individual components (again, from CA) and they should be exploded so that the material can be seamlessly wrapped around (and vertices welded in Thea). Same with your roof pieces. This is one of the reasons CA models are hard to work with in Thea, too.
                            Basically what you should do is too.
                          • delete all inner layers (like insulation and all),
                          • explode your wall pieces
                          • and run these two plugins after each other
                            http://forums.sketchucation.com/viewtopic.php?t=28087
                            http://forums.sketchucation.com/viewtopic.php?t=22920
                            (note that this second one needs an additional plugin library). This is the result after I first ran it:
                          • although first I would also get rid of the stone and brick materials, too since at some places, the walls are painted with both - depending on triangulation)
                            Imported stuff is often quite hard to work with before you really clean up what may be useful in other apps but useless in SU - also the export/import process may add a bunch of things that need to be cleaned first.
                            gelbuilding
                            Thanks Gaieus,
                            I will do what you suggested. Sounds good, i will post results
                            Thanks ever so much.
                              Here is also the model (I am sure there would still be place to reduce unnecessary complexity). Notice the difference in file size, too (almost half).
                              There is an inevitable problem however; unless your texture fits exactly around the model (or divided equally around the model), there will always be one edge where it does not fit seamlessly. Always put this edge (now find it behind) to where you will not examine the building - or break the completely continuous texture with some architectural element.
                              Edit: I also got your thea pack file but could not open or import it for some reason.
                              teststone.skp
                                gelbuilding
                                Hi Gaieus,
                                I like how the mesh gets cleaned up, though now when I do round corners to the brick opening around the door ie three edges and hit to round the whole face turns white. I don't understand why this occurs. Any suggestions what I'm doing wrong.
                                  Don't forget that this plugin creates new edges - and when coplanar edges that form a closed loop are created in SU, a face is also created. Just click on it to select and press delete (if I understand the problem clearly)
                                    gelbuilding
                                    Perfect Gaieus.
                                    All good. 😍
                                    Thanks ever so much for your help.
                                      Perfect! πŸ‘
                                      Now find something better stone texture for that house as I have not seen any similar flagstone cover since I visited some duke's manor somewhere near Chichester in Southern England a couple of years ago (or do they still build these in England?)
                                      πŸ˜†
                                        In East Anglia and the South East of the UK the vernacular style is called 'knapped-flint walling', there's usually a red clay-brick surround, or sometimes dressed stone trims... Flint cobbles are common in these mainly chalk-rock areas of the country, and it was a cheap and very durable building material, but now clay-brick is much cheaper and far less labor intensive because the flint cobbles have to be graded in size and they are often 'knapped' - i.e. effectively broken in half [but yours are 'unknapped'] ! It is still sometimes used for new building within conservation areas etc...
                                        Here's a few examplesflints-eg.gifm_Flint walling.jpgflintchalk.jpgKnapped-Flints-Ex-Chalk-Garden-Walling-Stone.jpg800px-Flint_Wall_Wiltshire.JPGeastbourne.pngffb3.png
                                          gelbuilding
                                          Thanks guys for your replies and here is one with a better stone texture i hope you like it.
                                          I like how now if i change the texture in Thea all the stone looks good. So the setup from Su must be very good because the stone still lines up.
                                            Look at some real stone buildings, compared to simple brickwork they will often have special 'quoin' stones to make wall corners and long stone sills and lintels at opening, and even special stone trims to opening reveals. These 'dressed-stone' items are often used in conjunction with the larger areas of less accurately made stonework
