    [Plugin] CleanUp
    974 Posts 217 Posters 861.8k Views 217 Watching
      hm... I cannot reproduce this at all.
      btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
      Also, do you have administrator access?
      • N Offline
        nomeradona
        thnaks thomas for the update.
        • Z Offline
          Zacchia
          Yes. I do this way. No messages in ruby console. Same thing in Windows 7 and XP.
          • Z Offline
            Zacchia
            Tom
            Can you send me the 3.1.4 Version again? I tried to replace the 3.1.6 with the 3.1.4 but the window is now also with 3.1.4 empty so I am not sure if I really have the 3.1.4 file...
              Can you try:
              1. Type in the Ruby Console: TT::Lib::VERSION
              2. Type in the Ruby Console: TT::System.temp_path
              3. Type in the Ruby Console: TT::Plugins::CleanUp::VERSION
              4. Right Click on the empty webdialog when you try "Clean..." and click Properties. Take a screenshot.
                @zacchia said:
                Tom
                Would you help trying to find the cause of the problem first? I'd like to get to the bottom of this.
                • jamalitoJ Offline
                  jamalito
                  thank so Thomas to your great work I have Q setup cleanup to my Su it tells mt it is need to TT_lib 2.5.4 but when I setup it Edge TOOL2 not work I don't know what is a problem ? thank Sir Thomas
                  my SU is SU8
                  Albert Einstein:
                  ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                    my SU is SU8
                    You're saying Edge Tools doesn't work for you when you update TT_Lib? What doesn't "work"? Error messages?
                    Have you ensured you also have the latest Edge Tools?
                      blajnov
                      @thomthom said:
                      my SU is SU8
                      Checked on a home computer, everything works fine, most likely due to adminpravami (at work today, he was absent), ie there is no access to the folder webdialog...
                      Thomas, thanks for the update plug-in.
                      • Z Offline
                        Zacchia
                        @thomthom said:
                        Can you try:
                        Well... this was in fact 2.5.4.... i am very sorry 😒 I was sure I changed to the new version but I did not! I am sorry and thank you so much for your support! Everything works fine now!
                        • Z Offline
                          Zacchia
                          Hi Tom
                          It's not over 😕 In office (XP) there I have still the problem, see screenshot. In Window 7 it is ok.
                            Cursed! 😞
                            Ok, can you Right Click and empty window and click "View Source" ?
                            • Z Offline
                              Zacchia
                              @thomthom said:
                              Cursed! 😞
                              In german lanuage "Quelltext anzeigen", hope you mean this...
                                I really do not understand why.
                                What is your Internet Explorer version btw?
                                • charly2008C Offline
                                  charly2008
                                  Hi Thomas.
                                  I have updated to version 3.1.6 but now no more menu box appears. I can run it but only with "Clean with last settings". What could be wrong? In the ruby console appears (see picture below)
                                  Charly
                                  Command: Clean
                                  Command: Clean with last settings
                                    That error indicate that you haven't updated TT_Lib2 to 2.5.5. It should have given you an error about that at startup, so I don't understand why you didn't. 😕
                                      charly2008
                                      Thanks for the tip, I had an older version of TT_Lib2. Now it works again.
                                      Charly
                                      • dereiD Offline
                                        derei
                                        @thomthom said:
                                        Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                                        Sorry,my mistake ! the model was on Monochrome style view and I forgot I had materials applied.That is why the Cleanup didn't worked as expected. It overlapped with plugin update, so I thought is a plugin issue.
                                        DESIGNER AND ARTIST DEREI.UK
                                        • Z Offline
                                          Zacchia
                                          1. IE? Why is this important?
                                            If it had been IE6 it would. WebDialogs use the IE engine under Windows.
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 46 / 49
