    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
    • Z
      Zacchia
      @thomthom said:
      Can you try:
      1. Type in the Ruby Console: TT::Lib::VERSION
      Well... this was in fact 2.5.4.... i am very sorry 😒 I was sure I changed to the new version but I did not! I am sorry and thank you so much for your support! Everything works fine now!
      • Z
        Zacchia
        Hi Tom
        It's not over 😕 In office (XP) there I have still the problem, see screenshot. In Window 7 it is ok.
          Cursed! 😞
          Ok, can you Right Click and empty window and click "View Source" ?
          • Z
            Zacchia
            @thomthom said:
            Cursed! 😞
            In german lanuage "Quelltext anzeigen", hope you mean this...
              I really do not understand why.
              What is your Internet Explorer version btw?
              • charly2008C
                charly2008
                Hi Thomas.
                I have updated to version 3.1.6 but now no more menu box appears. I can run it but only with "Clean with last settings". What could be wrong? In the ruby console appears (see picture below)
                Charly
                Command: Clean
                Command: Clean with last settings
                  That error indicate that you haven't updated TT_Lib2 to 2.5.5. It should have given you an error about that at startup, so I don't understand why you didn't. 😕
                  • charly2008C
                    charly2008
                    Thanks for the tip, I had an older version of TT_Lib2. Now it works again.
                    Charly
                    • dereiD
                      derei
                      @thomthom said:
                      Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                      Sorry,my mistake ! the model was on Monochrome style view and I forgot I had materials applied.That is why the Cleanup didn't worked as expected. It overlapped with plugin update, so I thought is a plugin issue.
                      DESIGNER AND ARTIST DEREI.UK
                      • Z
                        Zacchia
                        1. IE? Why is this important?
                          If it had been IE6 it would. WebDialogs use the IE engine under Windows.
                          • L
                            leocallejas
                            Hi ThomThom.... I just recently discovered your plugin, and I´m really excited to test it out, but I get that same blank window in Windows 7 x64 running Sketchup 8, and Internet Explorer 8. Here are my screenshots, maybe they'll help you sort it out.
                            Cheers! 😄
                            http://img694.imageshack.us/img694/8228/blankhr.jpg
                            http://img217.imageshack.us/img217/8760/versionsq.jpg
                            http://img821.imageshack.us/img821/6006/propertiest.jpg
                            http://img163.imageshack.us/img163/7218/sourceh.jpg
                              I'll post an update to TT_Lib shortly. Not sure if it helps, but we'll see.
                              Meanwhile, do you see a Compatibility Files button in Windows explorer when you view the plugins folder?
                              • Z
                                Zacchia
                                I do not understand this...
                                  Cheers! 😄
                                  Can you update to TT_Lib version 2.5.6 and report back if that made any difference?
                                    That was for leocallejas - he's on Vista. You won't see such a button in XP.
                                    If you want, you could try CleanUp 3.4.6 with TT_Lib 2.5.6 and see if that works.
                                    • B
                                      blajnov
                                      With the new library TT_Lib 2.5.6, the same problem, blank screen menu....
                                        sigh I'm completely stomped. I have no idea why it fails on one computer but not the other - without any errors... 😞
                                        I'm not sure how I can debug this, since I cannot reproduce it. ...maybe a Remote Desktop session... ?
                                        • B
                                          blajnov
                                          With the new library TT_Lib 2.5.6, the same problem, blank screen menu....[/quote]
                                          [quote:344sw0qv]
                                          I'm not sure how I can debug this, since I cannot reproduce it. ...maybe a Remote Desktop session... ?[/quote:344sw0qv]
                                          Returned to the library and TT_Lib 2.5.4 CleanUp 3.1.4, instead TT_Lib 2.5.6 and CleanUp 3.1.6, it worked ...
                                          It is unclear what the problem is!
                                            Did you try the file I sent you?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 48
                                            • 49
                                            • 22 / 49
