    [Plugin] CleanUp
    974 Posts 217 Posters 788.7k Views 217 Watching
      @driven said:
      @thomthom said:
      Version 3.1.5
      Minor update to fix an internal GC issue.
      should this remove the html temp files?
      No. Afraid not. Anything related to that will occur in TT_Lib. I'll have a proper patch in a day or two.
      • pep75P Offline
        pep75
          mberger
          Thank you.
          I have a feature request:
          Could you have the option to not purge components that are unused but have "XXXX_proxy" instances.
          I use the proxy feature in maxwell exporter a lot. It allows me to swap in the more complex geometry on export.
          Functionality would be a checkbox i think and an extra check when deleting an un used instance if the corresponding instance with _proxy appended to the name is used and iff that is true not delete it.
          • dereiD Offline
            derei
            It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
              What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
              Got sample model? And screenshot of settings?
              • 3 Offline
                3rdEye
                Hmmm, strange....
                when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
                I use SU 8 Pro, WinXP 32bit,
                but anyway - thx again for keeping it up!
                all the best, 3rdEye
                • dereiD Offline
                  derei
                  Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
                    Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                    • Z Offline
                      Zacchia
                      Tomtom
                      Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
                        @zacchia said:
                        Tomtom
                        Can you open the Ruby Console before you try "Clean..." and post back any errors?
                        • Z Offline
                          Zacchia
                          Same thing in office. See screenshot.
                            My bad. I made a minor change that required an update in TT_Lib2.
                            Version 3.1.6
                            Updated TT_Lib requirement to 2.5.5
                              blajnov
                              Version 3.1.6
                              Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
                                Any error messages this time?
                                Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                                  Just noticed something odd in your screenshot:
                                  "CleanUpi" - the title is suppose to be "CleanUp³" ... I wonder if your copy has been corrupted...
                                    blajnov
                                    Windows7 x64, previous versions worked flawlessly Cleanup
                                      Any error messages in the Ruby Console?
                                      Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                                      • Z Offline
                                        Zacchia
                                        Hi Tom
                                        No error message but just an empty window
                                          hm... I cannot reproduce this at all.
                                          btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
                                          Also, do you have administrator access?
                                          • N Offline
                                            nomeradona
                                            thnaks thomas for the update.
                                            • 48
                                            • 49
                                            • 3 / 49
