    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] CleanUp
    974 Posts 217 Posters 832.7k Views 217 Watching
      chango70
      Just great!
        Clean up of Clean up! ๐Ÿ˜‰
          @driven said:
          @thomthom said:
          Version 3.1.5
          Minor update to fix an internal GC issue.
          should this remove the html temp files?
          No. Afraid not. Anything related to that will occur in TT_Lib. I'll have a proper patch in a day or two.
          • pep75P Offline
            pep75
            ๐Ÿ‘ ๐ŸŽ‰
              mberger
              Thank you.
              I have a feature request:
              Could you have the option to not purge components that are unused but have "XXXX_proxy" instances.
              I use the proxy feature in maxwell exporter a lot. It allows me to swap in the more complex geometry on export.
              Functionality would be a checkbox i think and an extra check when deleting an un used instance if the corresponding instance with _proxy appended to the name is used and iff that is true not delete it.
              • dereiD Offline
                derei
                It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
                  What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
                  Got sample model? And screenshot of settings?
                  • 3 Offline
                    3rdEye
                    Hmmm, strange....
                    when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
                    I use SU 8 Pro, WinXP 32bit,
                    but anyway - thx again for keeping it up!
                    all the best, 3rdEye
                    • dereiD Offline
                      derei
                      Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
                        Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                        • Z Offline
                          Zacchia
                          Tomtom
                          Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
                            @zacchia said:
                            Tomtom
                            Can you open the Ruby Console before you try "Clean..." and post back any errors?
                            • Z Offline
                              Zacchia
                              Same thing in office. See screenshot.
                                My bad. I made a minor change that required an update in TT_Lib2.
                                Version 3.1.6
                                Updated TT_Lib requirement to 2.5.5
                                  blajnov
                                  Version 3.1.6
                                  Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
                                    โ“ โ“ โ“
                                    Any error messages this time?
                                    Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                                      Just noticed something odd in your screenshot:
                                      "CleanUpi" - the title is suppose to be "CleanUpยณ" ... I wonder if your copy has been corrupted...
                                        blajnov
                                        @thomthom said:
                                        :?: โ“ โ“
                                        Windows7 x64, previous versions worked flawlessly Cleanup
                                          @blajnov said:
                                          @thomthom said:
                                          :?: โ“ โ“
                                          Any error messages in the Ruby Console?
                                          Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                                          • Z Offline
                                            Zacchia
                                            Hi Tom
                                            No error message but just an empty window
                                            • 48
                                            • 49
                                            • 6 / 49
