    [Plugin] CleanUp
    974 Posts 217 Posters 992.0k Views 217 Watching
      Sakika
      Thanks for ur help TIG
      I really Apreciate it!
      Sakika
        bonobomidwest
        Thanks man. This was a HUGE help.
          I split off the discussion of the issues with Safari 5.0.6 into a separate thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=39842
            OSX Users:
            Download TT_Lib 2.5.5 for a patch that will fix the empty window.
            http://forums.sketchucation.com/viewtopic.php?f=323&t=30503
              Version 3.1.5
              Minor update to fix an internal GC issue.
                small08
                Thank-you TT, for all your hard work.
                  driven
                  @thomthom said:
                  Version 3.1.5
                  should this remove the html temp files?
                    Ben Ritter
                    Thank you!
                      putnik
                      Thank you Tom!
                      http://keshas.info
                        chango70
                        Just great!
                          Clean up of Clean up! 😉
                            @driven said:
                            @thomthom said:
                            Version 3.1.5
                            No. Afraid not. Anything related to that will occur in TT_Lib. I'll have a proper patch in a day or two.
                            • pep75P Offline
                              pep75
                                mberger
                                Thank you.
                                I have a feature request:
                                Could you have the option to not purge components that are unused but have "XXXX_proxy" instances.
                                I use the proxy feature in maxwell exporter a lot. It allows me to swap in the more complex geometry on export.
                                Functionality would be a checkbox i think and an extra check when deleting an un used instance if the corresponding instance with _proxy appended to the name is used and iff that is true not delete it.
                                • dereiD Offline
                                  derei
                                  It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
                                    What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
                                    Got sample model? And screenshot of settings?
                                    • 3 Offline
                                      3rdEye
                                      Hmmm, strange....
                                      when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
                                      I use SU 8 Pro, WinXP 32bit,
                                      but anyway - thx again for keeping it up!
                                      all the best, 3rdEye
                                      • dereiD Offline
                                        derei
                                        Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
                                          Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                                          • Z Offline
                                            Zacchia
                                            Tomtom
                                            Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 48
                                            • 49
                                            • 20 / 49
