    [Plugin] CleanUp
    974 Posts 217 Posters 834.3k Views 217 Watching
      putnik
      Thank you Tom!
      http://keshas.info
        chango70
        Just great!
          Clean up of Clean up! ๐Ÿ˜‰
            @driven said:
            @thomthom said:
            Version 3.1.5
            Minor update to fix an internal GC issue.
            should this remove the html temp files?
            No. Afraid not. Anything related to that will occur in TT_Lib. I'll have a proper patch in a day or two.
            • pep75P Offline
              pep75
              ๐Ÿ‘ ๐ŸŽ‰
                mberger
                Thank you.
                I have a feature request:
                Could you have the option to not purge components that are unused but have "XXXX_proxy" instances.
                I use the proxy feature in maxwell exporter a lot. It allows me to swap in the more complex geometry on export.
                Functionality would be a checkbox i think and an extra check when deleting an un used instance if the corresponding instance with _proxy appended to the name is used and iff that is true not delete it.
                • dereiD Offline
                  derei
                  It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
                    What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
                    Got sample model? And screenshot of settings?
                    • 3 Offline
                      3rdEye
                      Hmmm, strange....
                      when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
                      I use SU 8 Pro, WinXP 32bit,
                      but anyway - thx again for keeping it up!
                      all the best, 3rdEye
                      • dereiD Offline
                        derei
                        Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
                          Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                          • Z Offline
                            Zacchia
                            Tomtom
                            Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
                              @zacchia said:
                              Tomtom
                              Can you open the Ruby Console before you try "Clean..." and post back any errors?
                              • Z Offline
                                Zacchia
                                Same thing in office. See screenshot.
                                  My bad. I made a minor change that required an update in TT_Lib2.
                                  Version 3.1.6
                                  Updated TT_Lib requirement to 2.5.5
                                    blajnov
                                    Version 3.1.6
                                    Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
                                      โ“ โ“ โ“
                                      Any error messages this time?
                                      Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                                        Just noticed something odd in your screenshot:
                                        "CleanUpi" - the title is suppose to be "CleanUpยณ" ... I wonder if your copy has been corrupted...
                                          blajnov
                                          @thomthom said:
                                          :?: โ“ โ“
                                          Windows7 x64, previous versions worked flawlessly Cleanup
                                            @blajnov said:
                                            @thomthom said:
                                            :?: โ“ โ“
                                            Any error messages in the Ruby Console?
                                            Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 45 / 49
