    • Log Masuk
    [Plugin] CleanUp
    Scheduled Pinned Kunci Moved Plugins
    974 Kiriman 217 Posters 864.4k Lihat 217 Watching
    Memuatkan lagi kiriman
    • Lama ke Baru
    • Baru ke Lama
    Balas
    Log masuk untuk balas
    Topik ini telah dipadam. Hanya pengguna dengan kuasa pengurusan boleh melihatnya.
    • P Luar talian
      putnik
      Thank you Tom!
      http://keshas.info
      1 Reply Last reply Balas Petikan 0
      • C Luar talian
        chango70
        Just great!
        • pilouP Luar talian
          Clean up of Clean up! ๐Ÿ˜‰
          • thomthomT Luar talian
            @driven said:
            @thomthom said:
            Version 3.1.5
            Minor update to fix an internal GC issue.
            should this remove the html temp files?
            No. Afraid not. Anything related to that will occur in TT_Lib. I'll have a proper patch in a day or two.
            • pep75P Luar talian
              pep75
              ๐Ÿ‘ ๐ŸŽ‰
              • M Luar talian
                mberger
                Thank you.
                I have a feature request:
                Could you have the option to not purge components that are unused but have "XXXX_proxy" instances.
                I use the proxy feature in maxwell exporter a lot. It allows me to swap in the more complex geometry on export.
                Functionality would be a checkbox i think and an extra check when deleting an un used instance if the corresponding instance with _proxy appended to the name is used and iff that is true not delete it.
                • dereiD Luar talian
                  derei
                  It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
                  DESIGNER AND ARTIST DEREI.UK
                    What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
                    Got sample model? And screenshot of settings?
                    • 3 Luar talian
                      3rdEye
                      Hmmm, strange....
                      when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
                      I use SU 8 Pro, WinXP 32bit,
                      but anyway - thx again for keeping it up!
                      all the best, 3rdEye
                        derei
                        Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
                          Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
                          • Z Luar talian
                            Zacchia
                            Tomtom
                            Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
                              @zacchia said:
                              Tomtom
                              Can you open the Ruby Console before you try "Clean..." and post back any errors?
                              • Z Luar talian
                                Zacchia
                                Same thing in office. See screenshot.
                                  My bad. I made a minor change that required an update in TT_Lib2.
                                  Version 3.1.6
                                  Updated TT_Lib requirement to 2.5.5
                                  • B Luar talian
                                    blajnov
                                    Version 3.1.6
                                    Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
                                      โ“ โ“ โ“
                                      Any error messages this time?
                                      Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                                        Just noticed something odd in your screenshot:
                                        "CleanUpi" - the title is suppose to be "CleanUpยณ" ... I wonder if your copy has been corrupted...
                                        • B Luar talian
                                          blajnov
                                          @thomthom said:
                                          :?: โ“ โ“
                                          Windows7 x64, previous versions worked flawlessly Cleanup
                                            @blajnov said:
                                            @thomthom said:
                                            :?: โ“ โ“
                                            Any error messages in the Ruby Console?
                                            Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 48
                                            • 49
                                            • 17 / 49
