    Hello all ! new user to Google Sketchup seeking advice
    18 Posts 7 Posters 881 Views 7 Watching
    • charly2008C Offline
      charly2008
      Do not forget to Kerkythea
        That's an inexpensive and good option but...
        some basic Rendering
        ...it does have a learning curve considerably steeper than the others options
        • F Offline
          fasteddy
          I am downloading Twilight atm, will start playing around with it this weekend.
          I have attached a SU file of a basic ring which I want to render.
          S03.skp
          **Great minds discuss ideas;
          Average minds discuss events;
          Small minds discuss people.
          • Eleanor Rossevelt**
            To get accurate results rendering you need to follow real world dimensions. Also the inner surface of your ring has missing faces. These should be healed to create 'solid' object.
            Happy rendering 👍
            • F Offline
              fasteddy
              So just scale down the model ?
              And is can briefly describe healing?
              • cottyC Offline
                cotty
                Have a look at Indigo Renderer too!
                Cotty
                my SketchUp gallery
                • F Offline
                  fasteddy
                  So many choices!
                    There are some unneeded faces right inside the rings - look using a section-cut.
                    There are also some faces missing - draw over an edge and see it it 'heals' it with a new face [it might also make unwanted internal faces again - simply select the unwanted face[s] + delete key to remove those...].
                    Make sure that 'front' faces look outwards and the inner faces are the rear 'bluish' ones...
                    • cottyC Offline
                      cotty
                      @tig said:
                      look using a section-cut...
                      Nice trick to find unwanted internal faces with the ability to select them. Thanks!
                      Is there a plugin which deletes internal faces of a complex model automatically?
                      Cotty
                      my SketchUp gallery
                        Here is one: http://forums.sketchucation.com/viewtopic.php?p=92295#p92295
                        And here is your ring quick-rendered in Twilight.
                        • cottyC Offline
                          cotty
                          Thank you!
                          my SketchUp gallery
