    Hello all ! new user to Google Sketchup seeking advice
    18 Posts 7 Posters 1.1k Views 7 Watching
    • F Offline
      fasteddy
      Cheers Pilou, I will look into all to see what best suits!
      **Great minds discuss ideas;
      Average minds discuss events;
      Small minds discuss people.
      • Eleanor Rossevelt**
      • charly2008C Offline
        charly2008
        Do not forget to Kerkythea
          That's an inexpensive and good option but...
          some basic Rendering
          ...it does have a learning curve considerably steeper than the others options
          • F Offline
            fasteddy
            I am downloading Twilight atm, will start playing around with it this weekend.
            I have attached a SU file of a basic ring which I want to render.
            S03.skp
              To get accurate results rendering you need to follow real world dimensions. Also the inner surface of your ring has missing faces. These should be healed to create 'solid' object.
              Happy rendering 👍
              • F Offline
                fasteddy
                So just scale down the model ?
                And is can briefly describe healing?
                • cottyC Offline
                  cotty
                  Have a look at Indigo Renderer too!
                  Cotty
                  my SketchUp gallery
                  • F Offline
                    fasteddy
                    So many choices!
                      There are some unneeded faces right inside the rings - look using a section-cut.
                      There are also some faces missing - draw over an edge and see it it 'heals' it with a new face [it might also make unwanted internal faces again - simply select the unwanted face[s] + delete key to remove those...].
                      Make sure that 'front' faces look outwards and the inner faces are the rear 'bluish' ones...
                      • cottyC Offline
                        cotty
                        @tig said:
                        look using a section-cut...
                        Nice trick to find unwanted internal faces with the ability to select them. Thanks!
                        Is there a plugin which deletes internal faces of a complex model automatically?
                        Cotty
                        my SketchUp gallery
                          Here is one: http://forums.sketchucation.com/viewtopic.php?p=92295#p92295
                          And here is your ring quick-rendered in Twilight.
                          • cottyC Offline
                            cotty
                            Thank you!
                            my SketchUp gallery
