    [Plugin] CleanUp
    974 Posts 217 Posters 860.8k Views 217 Watching
      @driven said:
      @thomthom said:
      I hope it's a bug in that beta version.
      just did some checking and it's not a bug or a beta,
      it's now the current update with new security 'features'...
      5.0.6 for Leopard or 5.1 for Snow and Lion,
      anyone with auto update will already have this as well, there are no changes since the pre-release...
      Ah pooh! Cursed - now I got to dig into this new ... thing - whatever it is. Thanks for reporting though.
      And thanks for the webkit CSS tip. πŸ‘ πŸ‘
        Something's up with this .skp?
        uninitialized constant TT;;Sketchup
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;456;in `cleanup!'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;442;in `show_cleanup_ui'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;161;in `call'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;161;in `initialize'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;144;in `call'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;144;in `close'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;144;in `initialize'
        TT_CleanUp_Error.skp
          Actually getting this on any file?
            Yer CleanUp is out of date!
              Yer dead right πŸ‘
              I'd forgotten I'd updated TT_Lib2 with Quad Tools. My bad.
                Ye!
                • W Offline
                  wrc86
                  http://img580.imageshack.us/img580/8752/capturadepantalla201108ft.th.png
                  it's not working for me, it doesn't show any error when I start SU
                  It just to work with my old OS, now I'm working with OS X LION
                    hm... not sure what it could be. with no error message at all.
                    can you open the Ruby Console before you try to use CleanUp and see if you get any messages there?
                      Sakika
                      This might be a "stupid" question, but how do i install this plugin on sketchup? Because it is an .rb file and i dont know what program to open it?!
                      Thanks,
                      Sakika
                        Sakika
                        You really need to read some help files on general 'basic Plugin installation' πŸ˜•
                        You do not need to 'open' a Ruby .rb file at all [you can open it with a plain-text-editor and read it, as there are often 'notes' at the start, but its main contents might not be very easy to understand!].
                        You simply put the .rb file into the ../Sketchup../Plugins folder [there's a folder tree diagram].
                        Note that this particular tool also needs a 'TT_Lib2' - there's a link to get it on the tool's first 'download' page - this is a zipped folder of extra 'helper' files. The folder goes into Plugins with its files still inside it [there's a folder tree diagram to help you too] - Note: never move files out of these subfolders as it will break things! You then need to restart Sketchup to get everything operating.
                        The new tool will become available to you as explained in its installation/usage note... For this tools there's some 'Access' instructions and a screenshot of the menu item you should see...
                          Sakika
                          Thanks for ur help TIG
                          I really Apreciate it!
                          Sakika
                            bonobomidwest
                            Thanks man. This was a HUGE help.
                              I split off the discussion of the issues with Safari 5.0.6 into a separate thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=39842
                                OSX Users:
                                Download TT_Lib 2.5.5 for a patch that will fix the empty window.
                                http://forums.sketchucation.com/viewtopic.php?f=323&t=30503
                                  Version 3.1.5
                                  Minor update to fix an internal GC issue.
                                    small08
                                    Thank-you TT, for all your hard work.
                                      driven
                                      @thomthom said:
                                      Version 3.1.5
                                      should this remove the html temp files?
                                        Ben Ritter
                                        Thank you!
                                          putnik
                                          Thank you Tom!
                                          http://keshas.info
                                            chango70
                                            Just great!
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 44 / 49
