    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      Actually getting this on any file?
      Yer CleanUp is out of date!
        Yer dead right πŸ‘
        I'd forgotten I'd updated TT_Lib2 with Quad Tools. My bad.
          Ye!
          • W
            wrc86
            http://img580.imageshack.us/img580/8752/capturadepantalla201108ft.th.png
            it's not working for me, it doesn't show any error when I start SU
            It just to work with my old OS, now I'm working with OS X LION
              hm... not sure what it could be. with no error message at all.
              can you open the Ruby Console before you try to use CleanUp and see if you get any messages there?
                Sakika
                This might be a "stupid" question, but how do i install this plugin on sketchup? Because it is an .rb file and i dont know what program to open it?!
                Thanks,
                Sakika
                  Sakika
                  You really need to read some help files on general 'basic Plugin installation' πŸ˜•
                  You do not need to 'open' a Ruby .rb file at all [you can open it with a plain-text-editor and read it, as there are often 'notes' at the start, but its main contents might not be very easy to understand!].
                  You simply put the .rb file into the ../Sketchup../Plugins folder [there's a folder tree diagram].
                  Note that this particular tool also needs a 'TT_Lib2' - there's a link to get it on the tool's first 'download' page - this is a zipped folder of extra 'helper' files. The folder goes into Plugins with its files still inside it [there's a folder tree diagram to help you too] - Note: never move files out of these subfolders as it will break things! You then need to restart Sketchup to get everything operating.
                  The new tool will become available to you as explained in its installation/usage note... For this tools there's some 'Access' instructions and a screenshot of the menu item you should see...
                    Sakika
                    Thanks for ur help TIG
                    I really Apreciate it!
                    Sakika
                    • B
                      bonobomidwest
                      Thanks man. This was a HUGE help.
                        I split off the discussion of the issues with Safari 5.0.6 into a separate thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=39842
                          OSX Users:
                          Download TT_Lib 2.5.5 for a patch that will fix the empty window.
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=30503
                            Version 3.1.5
                            Minor update to fix an internal GC issue.
                              small08
                              Thank-you TT, for all your hard work.
                                driven
                                @thomthom said:
                                Version 3.1.5
                                should this remove the html temp files?
                                • B
                                  Ben Ritter
                                  Thank you!
                                  • P
                                    putnik
                                    Thank you Tom!
                                    http://keshas.info
                                    • C
                                      chango70
                                      Just great!
                                        Clean up of Clean up! πŸ˜‰
                                          @driven said:
                                          @thomthom said:
                                          Version 3.1.5
                                          No. Afraid not. Anything related to that will occur in TT_Lib. I'll have a proper patch in a day or two.
                                          • pep75P
                                            pep75
                                            πŸ‘ πŸŽ‰
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 48
                                            • 49
                                            • 20 / 49
