    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 130.8k Views 95 Watching
    • EscapeArtistE Offline
      EscapeArtist
      @arthur87 said:
      @dedmin said:
      Why not!? πŸ˜’
      of course artisan should be free..if a more advanced thing is for free then a basic version shouldn't come at a price...
      That might be an arguable position if the software was from the same developer, i.e. SDS1 should be free now that SDS2 is available; but as everyone has said, that's up to the dev, not us. SU by far has some of the least expensive add-ons of any program of its type - and most of those apps are made by community devs, the guys that help you every day to give you SU pointers and are right there to help you use their plug-in, not some impersonal corporate software powerhouse.
      What you're arguing is that if RenderMan was free, then the devs for Thea, Maxwell, Twilight and the rest should make their app free too. 10 years ago I might have argued for more free or open source apps, but nowadays there are so many good free apps out there that there's no excuse to look for warez. Blender, SU, Kerkythea, GiMP, DoubleCAD, InkScape, LuxRender...the list goes on. Scores of free, high-quality apps with hundreds of add-ons/plug-ins.
      Free has never had it so good.
      Sorry, a bit OT.
        FWIW, this was an old remark by "arthur87" and is moot now.
          EscapeArtist
          /me forgets to check self for necroposting.
          Sorry.
            πŸ˜†
            • BoxB Offline
              I've just been having my first play with Artisan and I have a problem.
              I ripped hole in the armpit, any Ideas/suggestions how to patch the hole?
                Tgi3D will select those boundary edges and 'Create Mesh' from the context menu will patch it. It's trial version will only work here as it's 'Training Edition' has a limit on the verts that can be meshed.
                Either that or export to another app for healing then import back.
                • BoxB Offline
                  Thanks Rich, I'll give Tgi3D a try when I get back from the pub.
                  • dereiD Offline
                    derei
                    Is it Artisan Forum still supported? I posted a question several days ago and no reply yet.
                    Also, I want to ask a question about how to use it. If I want the classic SDS behaviour, with Proxy and Subsurface, I need to run subdivide on a group first, then go inside that group, right? But when I run dubdivide on group, I can't choose how many iterations and as an example, in this moment, my SketchUp is not responding... and is doing this for more than 10 minutes yet... a little too much. If it tries to iterate 2 or 3 steps for starting, is a bullshit, because I don't want this. All I need is to have that two elements and continue editing the proxy.
                    There are many improvements since SDS, but still a lot of functions were taken away and replaced with something worse.
                    It would be awesome that this aspects to be revised.
                    The plugin is not intuitive at all 😞 I can use it, because I learned how to use it in the first place, and I used SDS before. But, for a newcomer is hard. It doesn't communicate with the user, one have to be sure to KNOW and remember everything from tutorials, because the plugin doesn't tell much. I'm sure that most time was spent on good functionality and I apreciate that a lot, but the interface and interaction with the user is equally important.
                    Thank you.
                    DESIGNER AND ARTIST DEREI.UK
                      Firstly, here's a link to the Quick card...
                      http://artisan4sketchup.com/downloads/docs/Artisan%20Quick%20Reference.pdf
                      Have you revised the settings to change the 'Create Proxy from group'? Are Subsurf Materials toggled to off?
                      Are you seeing a dialogue box popup when you subdivide a group. This allows you to set the iterations and to toggle auto-update.
                      Remember that Dale is a one man show and being August he could be on holidays?
                      • dereiD Offline
                        derei
                        Yes, thank you. I revised the settings, I watched again the tutorials, and it turned out that everything I done right. Maybe the problem is that on that file I ran before SDS and something made Artisan to not work properly. When I figured that, I exploded the group and started again. Some error alerts could help...
                        Thanks for answering.
                        • fredo6F Offline
                          There is a request from a user to put Artisan loader and folder in an alternate directory (defined by 000_AdditionalPluginFolders).
                          Apparently the icons do not show up, which may come from using a reference to Sketchup.find_support_file path (and not relative to the location of the folder).
                          • W Offline
                            Whaat
                            Hello,
                            I am not sure why SketchUp became unresponsive in your case. That is very unusual. If this is something that you are able to duplicate, I would like to see the SKP file for testing.
                            The plugin is not intuitive at all 😞 I can use it, because I learned how to use it in the first place, and I used SDS before. But, for a newcomer is hard. It doesn't communicate with the user, one have to be sure to KNOW and remember everything from tutorials, because the plugin doesn't tell much. I'm sure that most time was spent on good functionality and I appreciate that a lot, but the interface and interaction with the user is equally important.
                            I am sorry you feel this way. I worked hard on making the plugin intuitive and improving the workflow over SDS. If you have ideas on how to make things more intitive, please let me know.
                            Please note that the Artisan forum has now been discontinued. The quickest way to get support on Artisan is to use the contact form on the Artisan website:
                            http://artisan4sketchup.com/category/contact-us/
                            I will typically respond within 24 hours.
                            Thanks,
                            Dale
                            • JClementsJ Offline
                              JClements
                              Is there somewhere that demonstrates (or illustrates), how the Best, XY, YZ, and XZ options work?
                              I kind of have an idea, but how do they choose where the plane is placed relative to the coordinates of vertices selected? Especially with the Best option?
                                JClements
                                I must be doing something wrong. I don't the see how the Perpendicular and Camera Plane modes differ. Can someone demonstrate this?
                                • W Offline
                                  Whaat
                                  The position of the plane is always at the average position of the selected points (the centroid).
                                  With the 'best' option, the vertices are projected to the best-fit plane. In other words, the plane that results in the least amount of movement of the vertices from their original position.
                                  • W Offline
                                    Whaat
                                    With 'Perpindicular' move mode, the movement is constrained to the average normal (face direction) of the all of the selected faces. You can only move in one direction.
                                    With 'camera plane' mode, you can move in all directions that are on a plane perpindicular to the camera direction but you can not move in the direction that the camera is pointing.
                                    Hope that helps!
                                      baldaman
                                      Dear Mr MASTER WHAAT,
                                      a little question.
                                      There is an option for smoothed edges or not for the subsurf in the settings.
                                      We only have the choice between all smoothed or none smoothed, it would be fantastic to have the choice of the "angle between normals" like in the soften edges native SU dialog!
                                      And also why not dreaming: to establish a correspondance between proxies "angle between normals" edge softening and creased or not edges of that proxy.
                                      Sorry for my very bad english.
                                      PS: ARTISAN ROCKS! PROFILE BUILDER ROCKS!!!(the first and only software my former office was Ok to buy for me...)
                                      • soloS Offline
                                        Post wishes here: http://forums.sketchucation.com/viewtopic.php?f=323&t=40197
                                          AcesHigh
                                          Hi people... I am having some problems with the RoundCurve plugin by Fredo, and he suggested I should do what I intend with ARTISAN.
                                          I never used Artisan or Subdivide and Smooth... so I want to know if what I want to do is possible with ARTISAN and HOW to do it.
                                          Basically, what I have, is a square where I cut 2 of its corners with a bezier curve. Then I pushed/pulled the shape. I selected the top surface and applied Roundcurve, but for some reason, the plugin doesnt works well with bezier curves it seems, so the plugin offsets the curves but the offset "overlaps" itself in the curves, causing weird geometry.
                                          How can I have the same effect with Artisan?
                                          here is what happens when I try to use RoundCorner in my shape... first image shows the overlapping when offsetting the surface... second shows similar overlapping when using RoundCorner, and 3rd image shows the result of applying roundcorner when the curves overlap.
                                          3rd image also shows what I intend to do, so you guys can tell me if that is possible with Artisan and how you do that.
                                          I am also adding the shape that should be extruded and have its corners rounded with Artisan... so I hope you guys can confirm Artisan can do that and teach me how 😞 😞
                                          http://img542.imageshack.us/img542/8729/roundcorneroverlap.jpg
                                          artisantestshape.skp
                                          • hellnbakH Offline
                                            hellnbak
                                            Decided to set myself down and learn Artisan, and am having problems right off the bat. When I subdivide and smooth a cube, it does not come out smooth like the one in the how-to video. I ran 4 iterations just like in the video, and my results look more like a potato than the nice smooth result in the video. The subdivision patterns are different also.
                                            Here is what it should look like....
                                            and here's what I got......
                                            Don't know what I could be doing wrong, you select all the faces, and then subdivide and smooth four times, right? Just like in the video. If I can't get beyond the first basic step, I don't hold out much hope for getting very far with this. Any help will be much appreciated.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
