    [Plugin] TT_Lib²
    310 Posts 66 Posters 486.2k Views 66 Watching
      @dave r said:
      It worked fine then. I wonder if that file is write protected when SU is open and the file is in use.
      I sounds like SketchUp keeps a lock on the file when it's loaded. Probably because it's binary code instead of interpreted Ruby.
        rasstappen
        Sweet thanks-
        Rasstappen
          Version 2.5.4
          This update requires that you also update:
          • Edge Tools ( 2.0.3 )
          • Plan Tools ( 1.2.2 )
          • CleanUp ( 3.1.4 )
            Will TT_Lib ever be superseded by this? I know there are plugins that still require TT_Lib but it'd be nice to have all yours captured under TT_Lib2
              Selection Toys is the only one that requires TT_Lib version 1.
              Until Selection Toys is rewritten, into version 3, TT_Lib can not be made obsolete.
              The other plugins use TT_Lib 2 however.
              • B
                bitslapped
                I do love this plugin and use it a lot in complex models.
                What I would love is for the 'smooth angle' feature to have an 'ignore materials' checkbox, so that coplanar faces of different materials do not merge.
                E.g I have an organic surface with paths, lawn and garden beds on it. It would be great if the plugin smoothed the surface but left the edges between surface finishes.
                Thanks ThomThom, love your work.
                  I assume you are referring to the CleanUp plugin? (This is the TT_Lib thread...)
                  That would make it smooth the edge.
                  It's a good idea. I'll write it up for The List!
                  • B
                    bitslapped
                    Sorry, yes I was talking about Cleanup3.
                    Thanks for considering ThomThom, and yeah the 'ignore materials' was just using your existing terminology to add the feature.
                    Ideally it would be something like a "maintain material edges" checkbox.
                    Cheers mate, look forward to it 😄
                      Roger
                      ThomThom I am running 8 Pro and am trying to install "solid inspector." I have TT_Lib2 installed in the plugins folder and "tt_solid_inspector" installed in the "plug ins" folder.
                      When I start 8 I can not find any indciation of the programs existence. Any ieas of where I can begin looking for the problem?
                      Thanks.
                      http://www.azcreative.com
                      • K
                        kyyu
                        Thanks.
                        It saids the following, in the description. Did you check there?
                        Access
                        Tools > Solid Inspector
                          Roger
                          Thanks.
                          Access
                          I had to do a complete system restart before it appeared. Thanks Kwok
                          • L
                            LannorMov
                            Gracias TT.
                            Ya tenía caducada la versión anterior.
                              Version 2.5.5
                              Update for OSX users with Safari 5.0.6 or higher.
                              Not needed for Windows users.
                              Highly recommended for OSX users as Safari 5.0.6 will break some plugins with webdialogs.
                                driven
                                in 5.0.6
                                that seems to do the trick for cleanup [image with added css for scrollbar]
                                  Cursed! I knew I'd forgotten something! x_X
                                    Version 2.5.6
                                    Update that hopefully fixes what appear to be a regression from 2.5.4 to 2.5.5 for some Windows users.
                                      Version 2.5.7
                                      Fixes the fix for the OSX fix that broke WebDialogs for some Windows users. 😒
                                      ( I really hope everything is fixed now... 😕 )
                                        Version 2.5.8
                                        • Fixed some regression bugs in Inpubox
                                        Recommended update!
                                          driven
                                          You'll be happy to know it works here...
                                          I did tweek the height to 790 to stop the 'auto scrollbar' and added, ::-webkit-scrollbar to ui.css
                                          cheers
                                            Cheers. I've been too busy fixing the bugs to add this yet.
                                            • 15
                                            • 16
                                            • 3 / 16
