    [Plugin] TT_Lib²
    310 Posts 66 Posters 479.5k Views 66 Watching
      Selection Toys is the only one that requires TT_Lib version 1.
      Until Selection Toys is rewritten, into version 3, TT_Lib can not be made obsolete.
      The other plugins use TT_Lib 2 however.
      • B
        bitslapped
        I do love this plugin and use it a lot in complex models.
        What I would love is for the 'smooth angle' feature to have an 'ignore materials' checkbox, so that coplanar faces of different materials do not merge.
        E.g I have an organic surface with paths, lawn and garden beds on it. It would be great if the plugin smoothed the surface but left the edges between surface finishes.
        Thanks ThomThom, love your work.
          I assume you are referring to the CleanUp plugin? (This is the TT_Lib thread...)
          That would make it smooth the edge.
          It's a good idea. I'll write it up for The List!
          • B
            bitslapped
            Sorry, yes I was talking about Cleanup3.
            Thanks for considering ThomThom, and yeah the 'ignore materials' was just using your existing terminology to add the feature.
            Ideally it would be something like a "maintain material edges" checkbox.
            Cheers mate, look forward to it 😄
              Roger
              ThomThom I am running 8 Pro and am trying to install "solid inspector." I have TT_Lib2 installed in the plugins folder and "tt_solid_inspector" installed in the "plug ins" folder.
              When I start 8 I can not find any indciation of the programs existence. Any ieas of where I can begin looking for the problem?
              Thanks.
              http://www.azcreative.com
              • K
                kyyu
                Thanks.
                It saids the following, in the description. Did you check there?
                Access
                Tools > Solid Inspector
                  Roger
                  Thanks.
                  Access
                  I had to do a complete system restart before it appeared. Thanks Kwok
                  • L
                    LannorMov
                    Gracias TT.
                    Ya tenía caducada la versión anterior.
                      Version 2.5.5
                      Update for OSX users with Safari 5.0.6 or higher.
                      Not needed for Windows users.
                      Highly recommended for OSX users as Safari 5.0.6 will break some plugins with webdialogs.
                        driven
                        in 5.0.6
                        that seems to do the trick for cleanup [image with added css for scrollbar]
                          Cursed! I knew I'd forgotten something! x_X
                            Version 2.5.6
                            Update that hopefully fixes what appear to be a regression from 2.5.4 to 2.5.5 for some Windows users.
                              Version 2.5.7
                              Fixes the fix for the OSX fix that broke WebDialogs for some Windows users. 😒
                              ( I really hope everything is fixed now... 😕 )
                                Version 2.5.8
                                • Fixed some regression bugs in Inpubox
                                Recommended update!
                                  driven
                                  You'll be happy to know it works here...
                                  I did tweek the height to 790 to stop the 'auto scrollbar' and added, ::-webkit-scrollbar to ui.css
                                  cheers
                                    Cheers. I've been too busy fixing the bugs to add this yet.
                                      angelorea_arq
                                      look
                                      http://img194.imageshack.us/img194/6426/errorzoom.jpg
                                      Uploaded with ImageShack.us
                                      • N
                                        niks
                                        thank's so much for the update
                                          @angelorea_arq said:
                                          look
                                          What settings did you use for that?
                                          Also, could you post the reply in the CleanUp thread as the error is related to CleanUp and not TT_Lib?
                                            look
                                            Your profile says you use SU8, but exactly what version. The error was triggered in a part for SketchUp prior to SU8M1. Can you post your exact SketchUp version number in addition to the settings you used when you got the error?
                                            • 15
                                            • 16
                                            • 3 / 16
