    [Plugin] TT_Lib²
    310 Posts 66 Posters 486.2k Views 66 Watching
      Roger
      ThomThom I am running 8 Pro and am trying to install "solid inspector." I have TT_Lib2 installed in the plugins folder and "tt_solid_inspector" installed in the "plug ins" folder.
      When I start 8 I can not find any indciation of the programs existence. Any ieas of where I can begin looking for the problem?
      Thanks.
      http://www.azcreative.com
      • K
        kyyu
        Thanks.
        It saids the following, in the description. Did you check there?
        Access
        Tools > Solid Inspector
          Roger
          Thanks.
          Access
          I had to do a complete system restart before it appeared. Thanks Kwok
          • L
            LannorMov
            Gracias TT.
            Ya tenía caducada la versión anterior.
              Version 2.5.5
              Update for OSX users with Safari 5.0.6 or higher.
              Not needed for Windows users.
              Highly recommended for OSX users as Safari 5.0.6 will break some plugins with webdialogs.
                driven
                in 5.0.6
                that seems to do the trick for cleanup [image with added css for scrollbar]
                  Cursed! I knew I'd forgotten something! x_X
                    Version 2.5.6
                    Update that hopefully fixes what appear to be a regression from 2.5.4 to 2.5.5 for some Windows users.
                      Version 2.5.7
                      Fixes the fix for the OSX fix that broke WebDialogs for some Windows users. 😒
                      ( I really hope everything is fixed now... 😕 )
                        Version 2.5.8
                        • Fixed some regression bugs in Inpubox
                        Recommended update!
                          driven
                          You'll be happy to know it works here...
                          I did tweek the height to 790 to stop the 'auto scrollbar' and added, ::-webkit-scrollbar to ui.css
                          cheers
                            Cheers. I've been too busy fixing the bugs to add this yet.
                              angelorea_arq
                              look
                              http://img194.imageshack.us/img194/6426/errorzoom.jpg
                              Uploaded with ImageShack.us
                              • N
                                niks
                                thank's so much for the update
                                  @angelorea_arq said:
                                  look
                                  What settings did you use for that?
                                  Also, could you post the reply in the CleanUp thread as the error is related to CleanUp and not TT_Lib?
                                    look
                                    Your profile says you use SU8, but exactly what version. The error was triggered in a part for SketchUp prior to SU8M1. Can you post your exact SketchUp version number in addition to the settings you used when you got the error?
                                      Version 2.6.0
                                      • LibFredo Update Checker support.
                                      • Lots of new features and fixes.
                                      Important!
                                      QuadFace Tools users need to update to this version!
                                        mamoune12345
                                        Hello
                                        Can you tell me please how can i install the TT lib on the sketchup ?
                                        Thank you and sorry for my english 😄
                                        • mitcorbM
                                          mitcorb
                                          Hi mamoune:
                                          Go to the first post in the thread. Right click on the file tt_lib.zip, Save Link as... and save it to your computer, say, Desktop. Unzip the files to your Sketchup Plugins subfolder. As ThomThom says, this is not a stand alone plugin. It is a reference file for his other plugins.
                                          • T
                                            trinhsongoku
                                            thank you man[quote]
                                            • 15
                                            • 16
                                            • 3 / 16
