    Shell chair - Hans Wegner
    40 Posts 12 Posters 3.6k Views 12 Watching
    • Bryan KB Offline
      A classic.
      That's just straight SU? ๐Ÿ˜ฎ
      • massimoM Offline
        massimo Moderator
        Yeah. ๐Ÿ˜„
          That looks very nice. Good work.
          • massimoM Offline
            massimo Moderator
            Thank you Dave. ๐Ÿ˜„
              I have to ask. did you draw the joinery? ๐Ÿ˜‰
              • massimoM Offline
                massimo Moderator
                No joints, the pieces have just a bit of interpenetration. ๐Ÿ˜„
                • massimoM Offline
                  massimo Moderator
                  Here I've tried a first studio render with Thea. Changed the plywood texture. Only a slight high-pass filter in post pro. I wanted a "vintage" look...๐Ÿ˜„
                    Wow! That's very nice.
                    The only critiques I have, and most people probably wouldn't notice these things, is that the plywood texture on the seat back looks aged while the legs and stretchers don't have an aged look. The other thing is there appears to be a seam line in the texture on the right front leg. It looks like it runs parallel to the inside edge of the leg. If the leg were turned out of a laminated piece, the seam line would run straight down the leg on the axis./ That's mostly to prevent the glue line from showing as a parabolic curve on the side of the leg. Most likely the legs would be turned from several pieces.
                    As I said, most folks would never notice those things and you could leave them. It would pass as a photograph.
                    Excellent work.
                    • massimoM Offline
                      massimo Moderator
                      Thanks for the constructive criticisms Dave and yes, maybe I have to add some subtle scratches and stains on the legs and stretchers. ๐Ÿ˜„
                        I forgot to mention that I like those vertical lines in the seat back surface. They look like scratches that were there before the wood was re-varnished. And the color and texture just makes it look used. I think that used look is what is missing in a lot of renders. I'm sure it is difficult to get that look but for me, it's what tells me it's a computer generated thing and not a photograph. as I said, though, I don't think most folks would notice the things I pointed out.
                        • stefanqS Offline
                          stefanq
                          Great model and rendering, Massimo! I made some "more vintage" looks for your awesome image. I hope you don't mind... ๐Ÿ˜ณ
                          Regards,
                          Stefan
                          • massimoM Offline
                            massimo Moderator
                            Thanks Stefan, I don't mind at all and good work ๐Ÿ˜‰ (maybe the vignetting is just a bit too strong).
                            Anyway I have to say that I prefer the "original" image as it looks more "natural" to my eyes. ๐Ÿ˜„
                            • massimoM Offline
                              massimo Moderator
                              An update, now also the legs and stretchers have an aged look. ๐Ÿ˜„
                                Looks like it was used hard and then refinished. Nice, nice.
                                • massimoM Offline
                                  massimo Moderator
                                  Thanks again Dave. ๐Ÿ˜„
                                  Another couple of shots. Added a roughness map to the varnish of the woods and increased a bit the % of the roughness in order to have a different finishing. ๐Ÿ˜„
                                    Bellisimo!
                                    Is this a coating applied in Thea?
                                    Any chance I can see the Scattering and Structure settings? And Coating if you used it?
                                    • massimoM Offline
                                      massimo Moderator
                                      Grazie Rich. ๐Ÿ˜„
                                      Yes the wood mats have a stacked coating layer. Here are the settings I've used. As roughness map on the coating layer I've used the specular map. Only for the plywood I've increased the % of the roughness of the coating to 40.
                                        Excellent work.
                                          Thanks Massimo, appreciate it ๐Ÿ‘
                                          • massimoM Offline
                                            massimo Moderator
                                            Thanks Dave and Rich you're welcome. ๐Ÿ˜„
                                            The last image for this thread, I promise... ๐Ÿ˜† I gave them a home. ๐Ÿ˜„
