    Shell chair - Hans Wegner
    40 Posts 12 Posters 3.6k Views 12 Watching
    • dereiD Offline
      derei
      texturing looks nice. Why did you needed Thomthom's UV toolkit plugin? For edges? I'm thinking for plywood's faces you could project the texture.
      I'm asking this because, if you used some ingenious texturing procedure, to share it with us ๐Ÿ˜„
      DESIGNER AND ARTIST DEREI.UK
      • massimoM Offline
        massimo Moderator
        Exactly. You can apply the texture on the borders of a plain sheet and then, after bending, you can restore the UV as Gai explained in his tutorial on curved arcs. ๐Ÿ˜‰
        • dereiD Offline
          derei
          Can you point me on that tutorial? thanks ๐Ÿ˜„
          • massimoM Offline
            massimo Moderator
            Sure.
            http://forums.sketchucation.com/viewtopic.php?p=299717#p299717
            • HieruH Offline
              Hieru
              Excellent modelling and texturing ๐Ÿ‘
              Can we expect some Bertrand Benoit style renders? ๐Ÿ˜‰
              www.davidhier.co.uk
              • massimoM Offline
                massimo Moderator
                Thanks David. ๐Ÿ˜„
                Hehe, maybe I'll try some render.
                • Bryan KB Offline
                  A classic.
                  That's just straight SU? ๐Ÿ˜ฎ
                  • massimoM Offline
                    massimo Moderator
                    Yeah. ๐Ÿ˜„
                      That looks very nice. Good work.
                      • massimoM Offline
                        massimo Moderator
                        Thank you Dave. ๐Ÿ˜„
                          I have to ask. did you draw the joinery? ๐Ÿ˜‰
                          • massimoM Offline
                            massimo Moderator
                            No joints, the pieces have just a bit of interpenetration. ๐Ÿ˜„
                            • massimoM Offline
                              massimo Moderator
                              Here I've tried a first studio render with Thea. Changed the plywood texture. Only a slight high-pass filter in post pro. I wanted a "vintage" look...๐Ÿ˜„
                                Wow! That's very nice.
                                The only critiques I have, and most people probably wouldn't notice these things, is that the plywood texture on the seat back looks aged while the legs and stretchers don't have an aged look. The other thing is there appears to be a seam line in the texture on the right front leg. It looks like it runs parallel to the inside edge of the leg. If the leg were turned out of a laminated piece, the seam line would run straight down the leg on the axis./ That's mostly to prevent the glue line from showing as a parabolic curve on the side of the leg. Most likely the legs would be turned from several pieces.
                                As I said, most folks would never notice those things and you could leave them. It would pass as a photograph.
                                Excellent work.
                                • massimoM Offline
                                  massimo Moderator
                                  Thanks for the constructive criticisms Dave and yes, maybe I have to add some subtle scratches and stains on the legs and stretchers. ๐Ÿ˜„
                                    I forgot to mention that I like those vertical lines in the seat back surface. They look like scratches that were there before the wood was re-varnished. And the color and texture just makes it look used. I think that used look is what is missing in a lot of renders. I'm sure it is difficult to get that look but for me, it's what tells me it's a computer generated thing and not a photograph. as I said, though, I don't think most folks would notice the things I pointed out.
                                    • stefanqS Offline
                                      stefanq
                                      Great model and rendering, Massimo! I made some "more vintage" looks for your awesome image. I hope you don't mind... ๐Ÿ˜ณ
                                      Regards,
                                      Stefan
                                      • massimoM Offline
                                        massimo Moderator
                                        Thanks Stefan, I don't mind at all and good work ๐Ÿ˜‰ (maybe the vignetting is just a bit too strong).
                                        Anyway I have to say that I prefer the "original" image as it looks more "natural" to my eyes. ๐Ÿ˜„
                                        • massimoM Offline
                                          massimo Moderator
                                          An update, now also the legs and stretchers have an aged look. ๐Ÿ˜„
                                            Looks like it was used hard and then refinished. Nice, nice.
