    [Plugin] Recurve
    68 Posts 24 Posters 48.8k Views 24 Watching
      a necessary pest πŸ˜‰
        davidheim1
        Does the plug-in work with Mac OS? When I download the file, I get the code, not the usual files or folders.
        • jeff hammondJ Offline
          that's something to do with your browser maybe ?.. (though this does happen to me when i get rubies from crai but not when getting them from scf (using safari btw)
          right-click the download link and choose 'download linked file' (or something worded similarly) then the .rb should come in normal..
            mcpcorey
            Diggsey,
            I just wanted to say: THANK YOU, THANK YOU, for this plug in. In the relatively short time since I have started using it, it has saved me countless hours of frustration !.. I would have to say, (at least for the way I model) that this is probably the most useful, and time/frustration, saving plugin, that I have used to date.
            And a general shout out to all of you here that take the time to write, and share, such useful scripts!... You are way smarter than me, and you all deserve many accolades.. I don't know how I would get by without you all !
            Thanks Again !
            • W Offline
              Whaat
              Hey Diggsey,
              This looks like a great plugin. However, it doesn't seem to have the feature that I am most interested in.
              What would be very useful to me is if you could select two edges anywhere in a mesh and the plugin would try to find the shortest edge path in between them. A tool interface would be nice. You first select a single edge. Then, hold down 'shift' and click on another edge and all of the edges in between would be selected.
              This is actually the next plugin I was planning on writing but I haven't had the time to work on it yet. Is there any chance you could add this feature to your plugin?
                see this thread for ideas πŸ’š
                http://forums.sketchucation.com/viewtopic.php?f=323&t=30457
                (there's a video in the first post showing some sweet selecting)
                  Tgi3D Amorph has a funky selection tool
                  [flash=800,600:32tsmsqq]http://www.youtube.com/v/-0lmatxjuJM[/flash:32tsmsqq]
                    doesn't that plugin cost like 5 million dollars or something?
                      $150 for 2 licences.
                      Ramps for XGames cost 5 million bucks πŸ˜‰
                        bogmusic
                        Yo Diggsey
                        Superb tool - thanks
                        I will give more feedback when the work pressure drops a bit 😞
                          MartinK
                          Great plugin. Thanks. πŸ‘
                            leminilab
                            I should have thanked you sooner for this great plugin... β˜€
                            Now I'm being punished... πŸ‘Ώ
                            I use it quite often but it seems not to work anymore... I can't see the plugin upon right clicking or in the System Preferences/Extensions...
                            At least not with the 8.0.15158 (nice name for a version by the way... πŸ˜’ )
                            I think I could live without Recurving but I really got used to it now... I'm kind of hooked... πŸ˜•
                            Thanks a lot wor your plugin anyway! πŸ‘
                            • "Live every day as if it were your last and then some day you'll be right."
                            • "ThomThom rules!!!"
                            • BoxB Offline
                              This one doesn't seem to be working fully in 2014. It will recurve edges but it won't select curve and recurve.
                              It is one of my favourite tools, I had a shortcut key for it so you could click on any segment and with one keystroke it would find the path and weld it. I know other ways of doing it but they all require a couple of tools. I'm happy if someone can point me to one that works the same way.
                              Diggsey doesn't seem to have been around for a while, I hope he does pop up.
                                mcpcorey
                                Ditto... I get the same thing here, in 2014 the plug in will not select as it did in SU8 and 2013, Hopefully Diggsey will pop up, and make it fully compatible with 2014.
                                I will be hating life working without the full functionality of recurve in SU2014
                                Corey
                                • fredo6F Offline
                                  In the meantime, you could use Curvizard - Make Curve, if it helps.
                                  It has an entry in the contextual menu of SU selection and work on multiple contours at once.
                                  • BoxB Offline
                                    Thanks Fredo, yep I know and love your Curvizard, and all you tools. But what I miss in certain circumstances is the ability to click on one segment and hit a key and get the equivalent of Thomthom's select curve and weld all at once. If you can build that into curvizard I'd be a happy man.
                                    • Bob JamesB Offline
                                      Bob James
                                      +1
                                      • 4 / 4
