    [Plugin] Pen Tool +
    126 Posts 40 Posters 108.7k Views 40 Watching
      The 'edge' tools doesn't form faces like the 'pen' tool [or for that matter the other line drawing tools].. The 'pen' tool is like native 'Line'... BUT it has some different inferencing etc... Try the different ones to see what I mean... ๐Ÿค“
      • utilerU Offline
        utiler
        Hey, I've missed this so far!!!!! haven't you got enough to do, Rich?
        Well done mate!
        Just Curious...
          driven
          hi Rich,
          this is great, works on the mac except the
           ###new_toolbar.show ### ONLY show if was visible before...
              new_toolbar.restore if new_toolbar.get_last_state==TB_VISIBLE
          [this may be due to the slightly different RUBY_VERSION i.e. 1.8.5]
          however it does work if I cut and paste it to line 1175, directly under
          new_toolbar = UI;;Toolbar.new("Pen Tool +")
          tooltips, custom menu items and the tools themselves all work as advertised...
          well done
          • Rich O BrienR Online
            Thanks for the Mac feedback John. Glad you got it to work ๐Ÿ‘
            • yellow perilY Offline
              yellow peril
              I have just downloaded your pen tool, i am working on mac, it appears to workfine but with no icons.....any ideas?
                driven
                hi,
                if the icons folder named, rob_hsltool is in your plugins folder, then you might just need to turn on the menu in View >> Tool Palettes >> Pen Tool +
                • boofredlayB Offline
                  boofredlay
                  BTW, TIG solved my problem stated earlier in this thread. Thanks TIG.
                  It turns out if you click the "Compatibility Files" button between Burn and New Folder it showed up.
                  • H Offline
                    hungnguyenpham
                    Thank you!
                      Panga
                      Thanks a lot for this usefull plugins !! ๐Ÿ‘
                      • jgbJ Offline
                        jgb
                        @dave r said:
                        Comes of drinking American beer at high elevations for a week when you're not used to either. ๐Ÿ˜„
                        Canadian beer will do that at sea level in less than a day. ๐Ÿคฃ
                        jgb
                        • mitcorbM Offline
                          mitcorb
                          Hi:
                          Just trying out Pen Tool last night, I noticed that occasionally for one click I got 2 Cpoints. Also, one or two of the other pen settings doubled the endpoints which were placed short distances apart in a series of quick clicks randomly in the model space. Hard to explain. I did not save the file. This was in Sketchup 7. This mouse has shown no other misbehavior in other applications.
                          Has anyone else seen this?
                            Mitcorb I think this is down to you keeping the mouse-button pressed and dragging.
                            Most of this kind of line tools allow for you to press+hold+drag+release to make the line, as well as more usual click+click to provide two ends.
                            There's a short timer delay built-in to spot a real button-hold as that - obviously you're on the top limit time-wise and it's assuming a drag is wanted...
                            Is your mouse-button sticky?
                            For the cpoint tool if you don't do a clean click. but do more of a press. then it assume a drag and places a second cpoint at the release point - which might be only a short distance away if the mouse moves slightly.
                            So to avoid this ensure a clean click with no holding down of the mouse button with a drag unless you want two points...
                            ๐Ÿ˜•
                            • mitcorbM Offline
                              mitcorb
                              Yes, thanks, TIG:
                              It is obvious from only one test that I wasn't tuned in to the appropriate procedure. I am not usually what you would call a fast clicker, partly because of my system response, and partly because of my own internal wiring. ๐Ÿ’š
                              A salute to you and Rich for this excellent concept.
                              • N Offline
                                nanfar
                                thank you for you plugin.
                                  austin457
                                  Awesome. I joined this site specifically to get this plug-in. It's been a bane in my rear end that Sketchup couldn't simply draw dashed (or construction lines) that didn't go into infinity. Couldn't make a clean diagram that way. (And I know SU is more for 3D than CAD- but it makes sense to model something and then CAD it out in the same app. I also know Layout can draw them, but that gets messy too).
                                  I literally just used the plug-in, but something I noticed right off I want to ask about:
                                  I see that drawing the Construction lines flags to SU they are indeed construction lines. When I "Delete Guides" they are deleted as well. I tried grouping them and locking, but they still get deleted if I use the command. Is there a way to makes these lines unique to SU so they won't get deleted when cleaning up my drawings with the Delete Guides command?
                                  Thanks again. This will cut down on a lot of cursing 'round here! ๐Ÿ˜‰
                                  Win XP, SU 7
                                    Unfortunately no. Guides are deleted even in locked groups. I'd call this a bug but officially it is called a "feature".
                                    I am not really sure but as if in some earlier versions construction lines hadn't been deleted if they were in a group and you were outside that context. Just like how "unhide all" works now.
                                    You can always put these guides into a component (along with something else) however then right click and "Save as..." Later when you clean up your guides, right click on this component again and "Reload".
                                    I know it's a poor workaround but should do it.
                                      There are several tools knocking around that I and others made ages ago...
                                      Mine erases only those guide-lines or guide-points or both in the active context or current selection or 'all' if there's no selection - see here http://forums.sketchucation.com/viewtopic.php?p=341048#p341048 [I just modernized it a bit]
                                        boilingsnow
                                        Thank you Rich O'Brien!
                                        But the weld draw doesnt work by me.
                                        It always start from the origin point so I can't draw the line I want.
                                        Can you tell how to fix it?
                                        • irwanwrI Offline
                                          irwanwr
                                          ๐Ÿ‘ i am going to use this often
                                          thank you
                                          • E Offline
                                            eyein12
                                            ๐Ÿ‘Ž all pens draw from origin and thats it. is there something i'm missing
                                            • 4 / 7
