    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 170.5k Views 73 Watching
    • rohallorahR Offline
      rohallorah
      I have been looking for something like this for a long time now and I must say so far so good. I do a lot of interior related work so this is ideal. Been testing with Lithunwrap and seems to work fine so far.
      Here are 2 images I produced earlier on my thrid attampt:
      Sketchup Image
      http://i636.photobucket.com/albums/uu85/RobertOhalloran/UV Mapping with Sketchup/test.png
      VRAY Image
      http://i636.photobucket.com/albums/uu85/RobertOhalloran/UV Mapping with Sketchup/test_render.png
      Robert O'Halloran
      "Interior Architect & Designer"
      http://designermedia.ie
        leminilab
        Sketchup Image
        VRAY Image
        I was wondering what wrapping method you used for this?
        • "Live every day as if it were your last and then some day you'll be right."
        • "ThomThom rules!!!"
          rohallorah
          Hi, I used the planer mode in LithUnwrap if I'm not mistaken. Worked quite well I think πŸ˜„
          Robert O'Halloran
            leminilab
            @rohallorah said:
            Thank you! πŸ˜„
            Have a nice day!
            Nicolas
            • HieruH Offline
              Hieru
              I've been using this plugin today and it really is fantastic
              One problem I've noticed is that the textures (regardless of source image size) massively increase the file size. This means that the high poly chair I've been working on has increased from 4.75MB to 10.5MB, which means that I can't share the model via the 3D Warehouse.
              Is this because the OBJ file is bundled with the SU file, or is something else going on? Is there any way to get the file size back down again?
              www.davidhier.co.uk
                Alan Fraser recently identified that SU 7 & 8 do something with UV mapping that increases file size. It may effect 6 also I'm not sure. Nor do I remember where he mentioned it. What software are you mapping in?
                • HieruH Offline
                  Hieru
                  I'm using Ultimate Unwrap 3D.
                  www.davidhier.co.uk
                    How do you find it? I'm still getting to grips with it. Have you tried the .skp import/export feature? It's even great as a file conversion tool!
                    • HieruH Offline
                      Hieru
                      I haven't quite got my head around the full scope of the programme (looks promising though), but working in conjunction with Whaat's plugin I found it pretty intuitive. It's just a matter of figuring out the best UV mapping technique for your model.
                      I didn't see a .skp option, just .dae which crashed UU3D.
                      www.davidhier.co.uk
                        I had to contact the developer to get the .skp import/export to work. But now it's zipping along. Prior to that lots of splats.
                          shumas
                          Does any body gets an error when starting to download Ultimate Unwrap 3D from official site, it gives me that webpage requires JavaScript. Java is enabled on my explorer & mozilla,I dont get it... how can i download it guys ? πŸ˜•
                            Are you downloading the trial or the Licenced Pro/SE version?
                              shumas
                              It doesnt matter, it just wont let me download any version..
                                Did you email support? Brad is super helpful.
                                  shumas
                                  I didnt, i will try than to email for support, thanks for reply πŸ˜‰
                                    rcolpo
                                    My doubt is the most primary of all, cause I simply can not download the program, or install it. First, I failed to understand that the links in main message are not of the program. Then it took hours to me discover that I had to register on the site to download it. Then I finally see the hidden file, but it are an .rb, and I have no idea how to install it. Can someone help me? I'm exhausted and feeling stupid.
                                      Hi Rodrigo,
                                      Ruby plugins are "simple" text files wit the extension of *.rb (sometimes *.rbs). The way you install them is to simply copy them into this directory on your XP:
                                      C:\Program Files\Google\Google SketchUp 8\Plugins
                                      Then restart SU. Some plugins needs to be activated under Window > Preferences > Extensions (not this one however - as far as I remember). Then restart SU again. Some plugins have toolbars you can activate under View > Toolbars (usually somewhere at the bottom of the list - I cannot remember if this one has a toolbar - I doubt it).
                                      More complex plugins consist of several files and subfolders and are generally shared in ZIP archives here. Have a look here how to deal with them.
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                                      And of course, welcome to SCF (and to advanced SU use...) There are some marvellous plugins shared by these generous authors here.
                                        rcolpo
                                        Thanks for helping! πŸ˜„ The UV Mapping Software I used was the Ultimate Unwrap 3D. Thanks.
                                        • dereiD Offline
                                          derei
                                          A little late, but shouldn't this plugin be renamed in something more suggestive? Like "UV Mapping Tools" ?
                                          There is another "UVTools" plugin here http://rhin.crai.archi.fr/rld/plugin_details.php?id=459
                                            That's also by Whaat (Dale Martens) like this one. That's why this is called
                                            UV Tools 2.
                                            • 7 / 10
