    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 180.9k Views 73 Watching
    • HieruH Offline
      Hieru
      I've been using this plugin today and it really is fantastic
      One problem I've noticed is that the textures (regardless of source image size) massively increase the file size. This means that the high poly chair I've been working on has increased from 4.75MB to 10.5MB, which means that I can't share the model via the 3D Warehouse.
      Is this because the OBJ file is bundled with the SU file, or is something else going on? Is there any way to get the file size back down again?
      www.davidhier.co.uk
        Alan Fraser recently identified that SU 7 & 8 do something with UV mapping that increases file size. It may effect 6 also I'm not sure. Nor do I remember where he mentioned it. What software are you mapping in?
        • HieruH Offline
          Hieru
          I'm using Ultimate Unwrap 3D.
          www.davidhier.co.uk
            How do you find it? I'm still getting to grips with it. Have you tried the .skp import/export feature? It's even great as a file conversion tool!
            • HieruH Offline
              Hieru
              I haven't quite got my head around the full scope of the programme (looks promising though), but working in conjunction with Whaat's plugin I found it pretty intuitive. It's just a matter of figuring out the best UV mapping technique for your model.
              I didn't see a .skp option, just .dae which crashed UU3D.
              www.davidhier.co.uk
                I had to contact the developer to get the .skp import/export to work. But now it's zipping along. Prior to that lots of splats.
                  shumas
                  Does any body gets an error when starting to download Ultimate Unwrap 3D from official site, it gives me that webpage requires JavaScript. Java is enabled on my explorer & mozilla,I dont get it... how can i download it guys ? πŸ˜•
                    Are you downloading the trial or the Licenced Pro/SE version?
                      shumas
                      It doesnt matter, it just wont let me download any version..
                        Did you email support? Brad is super helpful.
                          shumas
                          I didnt, i will try than to email for support, thanks for reply πŸ˜‰
                            rcolpo
                            My doubt is the most primary of all, cause I simply can not download the program, or install it. First, I failed to understand that the links in main message are not of the program. Then it took hours to me discover that I had to register on the site to download it. Then I finally see the hidden file, but it are an .rb, and I have no idea how to install it. Can someone help me? I'm exhausted and feeling stupid.
                              Hi Rodrigo,
                              Ruby plugins are "simple" text files wit the extension of *.rb (sometimes *.rbs). The way you install them is to simply copy them into this directory on your XP:
                              C:\Program Files\Google\Google SketchUp 8\Plugins
                              Then restart SU. Some plugins needs to be activated under Window > Preferences > Extensions (not this one however - as far as I remember). Then restart SU again. Some plugins have toolbars you can activate under View > Toolbars (usually somewhere at the bottom of the list - I cannot remember if this one has a toolbar - I doubt it).
                              More complex plugins consist of several files and subfolders and are generally shared in ZIP archives here. Have a look here how to deal with them.
                              http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                              And of course, welcome to SCF (and to advanced SU use...) There are some marvellous plugins shared by these generous authors here.
                                rcolpo
                                Thanks for helping! πŸ˜„ The UV Mapping Software I used was the Ultimate Unwrap 3D. Thanks.
                                • dereiD Offline
                                  derei
                                  A little late, but shouldn't this plugin be renamed in something more suggestive? Like "UV Mapping Tools" ?
                                  There is another "UVTools" plugin here http://rhin.crai.archi.fr/rld/plugin_details.php?id=459
                                  DESIGNER AND ARTIST DEREI.UK
                                    That's also by Whaat (Dale Martens) like this one. That's why this is called
                                    UV Tools 2.
                                      Surely you mean UV Tools 0.2 Pro Beta?
                                        Whatever. It's still early in the morning here (1:33 PM) 😳
                                          No offence meant as I can relate to dereeei's confusion. But UV Tools only maps cylindrical and spherical objects within SU. Whereas UV Tools 0.2 Pro Beta exports/imports to .obj for mapping in external app.
                                          As for changing the name, I imagine Dale viewed UV Tools 0.2 Pro Beta as an extension to UV Tools. Both work a treat which is what everyone wants.
                                          Whatever πŸ˜‰
                                          • X Offline
                                            xJonnx
                                            Looks like a good idea, but does not import into Blender 2.45
                                            • 7 / 10
