    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 170.5k Views 73 Watching
    • Rich O BrienR Online
      I had to contact the developer to get the .skp import/export to work. But now it's zipping along. Prior to that lots of splats.
        shumas
        Does any body gets an error when starting to download Ultimate Unwrap 3D from official site, it gives me that webpage requires JavaScript. Java is enabled on my explorer & mozilla,I dont get it... how can i download it guys ? πŸ˜•
          Are you downloading the trial or the Licenced Pro/SE version?
            shumas
            It doesnt matter, it just wont let me download any version..
              Did you email support? Brad is super helpful.
                shumas
                I didnt, i will try than to email for support, thanks for reply πŸ˜‰
                  rcolpo
                  My doubt is the most primary of all, cause I simply can not download the program, or install it. First, I failed to understand that the links in main message are not of the program. Then it took hours to me discover that I had to register on the site to download it. Then I finally see the hidden file, but it are an .rb, and I have no idea how to install it. Can someone help me? I'm exhausted and feeling stupid.
                    Hi Rodrigo,
                    Ruby plugins are "simple" text files wit the extension of *.rb (sometimes *.rbs). The way you install them is to simply copy them into this directory on your XP:
                    C:\Program Files\Google\Google SketchUp 8\Plugins
                    Then restart SU. Some plugins needs to be activated under Window > Preferences > Extensions (not this one however - as far as I remember). Then restart SU again. Some plugins have toolbars you can activate under View > Toolbars (usually somewhere at the bottom of the list - I cannot remember if this one has a toolbar - I doubt it).
                    More complex plugins consist of several files and subfolders and are generally shared in ZIP archives here. Have a look here how to deal with them.
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                    And of course, welcome to SCF (and to advanced SU use...) There are some marvellous plugins shared by these generous authors here.
                      rcolpo
                      Thanks for helping! πŸ˜„ The UV Mapping Software I used was the Ultimate Unwrap 3D. Thanks.
                      • dereiD Offline
                        derei
                        A little late, but shouldn't this plugin be renamed in something more suggestive? Like "UV Mapping Tools" ?
                        There is another "UVTools" plugin here http://rhin.crai.archi.fr/rld/plugin_details.php?id=459
                          That's also by Whaat (Dale Martens) like this one. That's why this is called
                          UV Tools 2.
                            Surely you mean UV Tools 0.2 Pro Beta?
                              Whatever. It's still early in the morning here (1:33 PM) 😳
                                No offence meant as I can relate to dereeei's confusion. But UV Tools only maps cylindrical and spherical objects within SU. Whereas UV Tools 0.2 Pro Beta exports/imports to .obj for mapping in external app.
                                As for changing the name, I imagine Dale viewed UV Tools 0.2 Pro Beta as an extension to UV Tools. Both work a treat which is what everyone wants.
                                Whatever πŸ˜‰
                                • X Offline
                                  xJonnx
                                  Looks like a good idea, but does not import into Blender 2.45
                                    Try to triangulate the faces before using the plugin and export afterwards. Distorted materials in SU often fail to export (unless the author of the exporter is aware of this glitch and programs the exporter to overcome this bug).
                                    Here are some plugins that do this for you:
                                    http://forums.sketchucation.com/viewtopic.php?t=23638
                                    http://forums.sketchucation.com/viewtopic.php?t=20347
                                    • X Offline
                                      xJonnx
                                      Thanks for the links. Tried the triangulate plugin. It worked great! However, still gives an error when trying to import into Blender. Tried both v 2.45 and 2.49
                                        Is that an error message or just fails to import or just fails to import when processed with UV tools?
                                        • X Offline
                                          xJonnx
                                          I get an error message and it fails to import when using UV Tools. I can open it in Blender when converting the .kmz file to colada
                                            A kmz file is just a compressed folder with the collada (dae) file - and the materials - inside. Are you saying that when you export to collada (or convert/extract the kmz file to collada) the import is okay?
                                            If you rename the kmz extension to zip, you can see what I mean.
                                            • 8 / 10
