    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      liviuroman
      Google SketchUp 8 - Windows 7 x64
      Error; #<NoMethodError; undefined method `all_connected' for #<Sketchup;;ComponentInstance;0xaccf740>>
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb;307;in `line_picker'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb;239;in `onLButtonUp'
      • Chris FullmerC Offline
        That looks like a problenm with what you are selecting. I think you need to have just a single component selected when you begin the tool. Then click on a line.
        Could you upload the model you tried it on? I could look at it and see what is wrong,
        • charly2008C Offline
          charly2008
          I'm still experimenting with the different profiles and different paths.
          In the example shown below,at the first step the profile is messed up. But that's not a problem. Press the up arrow key and then the down arrow key and the profile is then aligned.
          Charly
            liviuroman
            I solved the problem. I didn`t have any line parallel to x-axis (red axis).
              charly2008
              Another attempt.
                charly2008
                here again, the individual steps.
                Charly
                ShapeBender1.skp
                  cancincon
                  Hello,
                  First of all I thank you a lot for the script, a great idea and a great work.
                  However I am having trouble with making it work, probably because i am being a noob, but i would still appreciate some help.
                  When I try to make the script work it tells me to "select something" even though I already selected the object.
                  I tried many times but still get this error.
                  Can anyone point me out what i am doing wrong?
                    Did you select a component before trying to run the plugin?
                      cancincon
                      yes i did 😐
                        Did you perhaps select a group instead?
                          cancincon
                          hmm...maybe...
                          well i am not even sure, i just made a cylinder and clicked on it with selection tool so it turns blue (so this is where i thought i selected it)
                          Sorry, i know it sounds stupid but i would still appreciate some pointers about how to use this plug-in : (
                            You need a 'Group' of geometry that you want to 'bend', a straight 'Line' parallel with the X-axis [Red] that determines the extents of the bending [note that this line cannor be connected to anything else!] and a 'curve' [i.e. an Arc, Bezier or collection of Edges 'Welded' into a Curve] that the bend will follow.
                            To make a group select your required geometry [e.g. your cylinder] right-click and 'Make Group'; it now selects as a single object because the geometry is inside it [you can also use a component-instance instead of a group - then use 'Make Component'!]...
                            The relative placement of the group[or component], the line and the curve affect the resultant bending.
                            Select the group[or component] and start the 'Shape Bender' tool.
                            Follow the prompts - pick the line - then pick the curve - swap the start/end with arrow-keys IF required [e.g. the ghost-image of the potential bent result looks 'twisted'].
                            Press <enter> and the group is copied in a 'bent' form, as a new 'shape bender component'...Capture.PNG
                              You made a cylinder - as in you drew a circle and push-pulled it? Then what? Did you group it or make it into a component?
                                cancincon
                                Press <enter> and the group is copied in a 'bent' form, as a new 'shape bender component'...[attachment=0:31120sgk]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:31120sgk]
                                Phew...that did it
                                Thanks to everyone who bothered to give an answer, I appreciate it : ))
                                  avraz
                                  first of all thanks alot for your work -i just bought your repeat copy plug for landscaping and im very happy with it
                                  i also got the shape bender which i really enjoy playing with .
                                  the problem is-it works on 2 computers in version 7 but on my version 8 which i got alot of plugins installed in it , as soon as i pick the component and the 2 lines it starting to process and get stuck on 1-7% and writes that it is looking for components to explode
                                  i tried with a component and with a group i tried reenstalling it ,the shapes i used r as simple as they come and my computer is very strong
                                  my best guess is that is is clashing with another plugin
                                  i got about 100 plugins so if you know of such plug that might be causing such a problem it will help alot
                                    Have you installed progressbar.rb on both PCs ?
                                      avraz
                                      yes i did
                                      on the same computer i got v7 that works but got very few plugs in its library and v8 with alot of plugs that doesnt work correctly
                                        araz
                                        @tobobo said:
                                        Do you have to mist uptodate Compent Spray plugin?, as i believe there is a clash with bender and the previous plugin.
                                        i removed the component spray and it worked
                                        thanks alot for the advice-problem solved
                                        • ToboboT Offline
                                          Tobobo
                                          Do you have the most up to date Compent Spray plugin? as i believe there is a clash with bender and the previous version of the plugin.
                                          Toby
                                          Philippians 4:13
                                          • ToboboT Offline
                                            Tobobo
                                            the new version of component spray works with the bender plugin
                                            Apologise for the poor typing, i've corrected the post 😳
                                            Toby
                                            Philippians 4:13
                                            • 63
                                            • 64
                                            • 7 / 64
