    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
      This thing is killer
      • charly2008C
        charly2008
        Hi Chris, Marcus, Rich,
        thanks for your quick response. In my experience the reverse of start - end has only the effect that the bended part is within or outside of the curve.
        Charly
        • charly2008C
          charly2008
          Hi All,
          the error shown above occurs sporadically and over again. If I download the same file again the same error appears. After a restart SketchUp, and with a new model, the faulty behavior is gone. I've uploaded the file. Maybe one of you can open the file again and check whether the error also appears. Thanks in advance.
          Charly
          ShapeBender.skp
            I was getting the same results you show in your first image. How did you get it to work?
            • jeff hammondJ
              push the Down arrow
                SketchUpNoobie
                Karlheinz, I've been having the same thing happen to me lately. Tap the down arrow key. That fixes it for me. 😄
                Chris, out of curiosity, what does the down arrow key do exactly? 😕
                Edit: I've been beat. Sorry. 😳
                SketchUpNoobie: the complete noob in all things SketchUp.
                  I used the Up arrow to change swap ends on the curve. Didn't try the down arrow to swap ends on the straight line. Weird.
                  • charly2008C
                    charly2008
                    Hi Dave,
                    I started sketchup again and made a new model then it worked. Strange!
                    Charly
                    • charly2008C
                      charly2008
                      With a little imagination you can create some interesting shapes.
                        Reminds me of hook worms. 😄
                        • charly2008C
                          charly2008
                          by ShapeBender
                          • V
                            vidy
                            surely nice try charly 👍
                            still so much to learn..
                            • Chris FullmerC
                              What the up and down arrow keys do is reverse the start and end points of the shape and the line. They should always be to the "left" of the model. This is mostly due to my poor programming skills at the time I made this thing, this was afterall my 3rd plugin I'd ever written. When you press the up/down key, you should see the start and end tags flipping places. And when you press the left/right keys, the other start/end tags will flip places. Please align them to the "left" side. If you are looking straight down on the model, with the solid red line going out to the right, then both "start" tags should be on the left of the model. I don't know how to make it more clear unfortunately. Its a little bit of bad programming, and a lot of "the ruby script can't read your mind". It needs to know which end of the shape should match up to which end of the line. Choosing the wring thing will cause the results you are seeing.
                              The reason it work once the model is closed and re-opened is because SketchUp does not remember the start and end positions of lines in between sessions - once the model is close, SU dumps its memmory of start and end. So often they come in backwards of what they were originally, meaning my script will interperet the start and end differently.
                              Anyhow, just play with pressing up/down and left/right and get good at making the starts both line up on the "left" side of the model (also known as the more negative x value, if that makes more sense in your head).
                              Good luck!
                                Thanks for the explanation Chris. Much appreciated.
                                FWIW, on my computer, the Up arrow toggles the start and end positions on the curve and the Down Arrow toggles the start and end positions for the straight line. The Left and Right arrows don't do diddly.
                                  SketchUpNoobie
                                  That helps a bunch! Thanks!
                                  Mine works the same way. 😕
                                  • charly2008C
                                    charly2008
                                    This opens up many possibilities for jewelry or stucco designs. Who has other ideas.
                                    Charly
                                      d12dozr
                                      Those are some wild shapes, Charly 👍
                                      http://goo.gl/f7ooYh
                                      • Chris FullmerC
                                        Thanks for clarifying Dave - I have not used the plugin in a whle obviously!, I've forgotten how it works apparently.
                                        Great shapes there Charly, looks like you're getting the hang of shapebender quite nicely now!
                                        • charly2008C
                                          charly2008
                                          Thanks Chris
                                          could be interesting also for wood working.
                                          Charly
                                          • L
                                            liviuroman
                                            Google SketchUp 8 - Windows 7 x64
                                            Error; #<NoMethodError; undefined method `all_connected' for #<Sketchup;;ComponentInstance;0xaccf740>>
                                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb;307;in `line_picker'
                                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb;239;in `onLButtonUp'
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 63
                                            • 64
                                            • 40 / 64
