    Island Queen
    38 Posts 13 Posters 16.0k Views 13 Watching
    • KrisidiousK Offline
      Krisidious
      whoa... that's awesome. great lighting the reflections and refractions are perfect. nice wood floor too...
      By: Kristoff Rand
      • daleD Offline
        dale
        It's nice to see this real WIP.
        I appreciate your taking the time to share as your going along, it will certainly give me insight, but I think will also show some of the new users the potential. 👍
          Slimdog
          Very inspiring work here.
            agamemnus
            Nice interior, bridge, and antenna work.
            Unless you're modeling from the real thing, I would make the ceiling lights brighter, possibly reduce the amount of window lights by half, and reduce the window lights' intensity somewhat, too. There's just too much light there... you don't want the glare of that lamplight when you are sitting there, looking at the ocean or coastline.
            • boofredlayB Offline
              boofredlay
              I am enjoying your progress Bruce. Nice.
                Krisidious
                Vue and the 3D simulator I mentioned...
                By: Kristoff Rand
                  d12dozr
                  This one has worked well for me: ($49.95) http://www.cornucopia3d.com/purchase.php?item_id=8911
                  http://goo.gl/f7ooYh
                    boofredlay
                    Funny think happened on the way to rendering this project. ...
                    I guess I don't have the modeling skills to satisfy any type of export to Thea. I have exausted my experiments including loading, reloading all applications, so for now with sadness I am putting Thea away.
                    If anyone has suggestions on another engine that will work well in the context of this boat project please let me know. I am aware of popular engines sold here but not sure how to pick anymore.
                    What is the problem? Is it just the material application?
                    Could you post up the model here and see if someone else with Thea can test it?
                      boofredlay
                      After a quick look I don't see the problem. I don't see any extra faces in Thea.
                      Here is a view from SU and one from Thea with some materials applied.
                      (I only have the trial of Thea at work hence the watermark).
                      • N Offline
                        notareal
                        Have to agree with Boo, when looking the model I don't see any particular reasons why it should not export perfectly. For me the scene works just fine 😕 . Use of single sided geometry may cause issues with adaptive BSD, but for progressive BSD and unbiased TR1/TR2 it's not a issue. But it would not explain "coloring" issues... I'd say that the model is fine.
                        Only one good reason I can figure is that SU2TH does not recognize the license. If that's the case, then SU2TH is run in demo mode and if you have licensed Thea, then material from random triangles is dropped. Please verify the license...
                        In command prompt
                        In Mac try open -a Thea.app --args thea -license sketchup -matlab
                        In windows try Thea.exe thea -license sketchup -matlab
                        If matlab opens in demo mode, then something has gone wrong with the license.
                          boofredlay
                          Good luck and happy rendering, that is an order 😉
                            boofredlay
                            Hang in there.
                              KarinaGM
                              Loving it!
                              **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                              -Benjamín Franklin.**
                              • numbthumbN Offline
                                numbthumb
                                Can´t believe I missed this. Excellent work! 👍
                                Comfortably numb...
                                • N Offline
                                  notareal
                                  Maybe a underwater render with that material, broken windows...
                                    KarinaGM
                                    Wooowow
                                    And you say you need assistance?
                                    The 1st image of this last message is just great!
                                      numbthumb
                                      You´ve tied this one pretty well 😉
                                      Comfortably numb...
                                        numbthumb
                                        And how did you make your water?
                                        Comfortably numb...
                                          numbthumb
                                          Thanks for the thorough response.
                                          Comfortably numb...
                                          • Bryan KB Offline
                                            Wow. Looking better and better.
