    Island Queen
    38 Posts 13 Posters 16.1k Views 13 Watching
    • Bryan KB Offline
      Definitely looking good.
      • KrisidiousK Offline
        Krisidious
        you should put that boat in this sim... if not just for the video of it.
        404 Error
        (www.hangsim.com)
        By: Kristoff Rand
          Krisidious
          whoa... that's awesome. great lighting the reflections and refractions are perfect. nice wood floor too...
          By: Kristoff Rand
          • daleD Offline
            dale
            It's nice to see this real WIP.
            I appreciate your taking the time to share as your going along, it will certainly give me insight, but I think will also show some of the new users the potential. 👍
              Slimdog
              Very inspiring work here.
                agamemnus
                Nice interior, bridge, and antenna work.
                Unless you're modeling from the real thing, I would make the ceiling lights brighter, possibly reduce the amount of window lights by half, and reduce the window lights' intensity somewhat, too. There's just too much light there... you don't want the glare of that lamplight when you are sitting there, looking at the ocean or coastline.
                • boofredlayB Offline
                  boofredlay
                  I am enjoying your progress Bruce. Nice.
                    Krisidious
                    Vue and the 3D simulator I mentioned...
                    By: Kristoff Rand
                      d12dozr
                      This one has worked well for me: ($49.95) http://www.cornucopia3d.com/purchase.php?item_id=8911
                      http://goo.gl/f7ooYh
                        boofredlay
                        Funny think happened on the way to rendering this project. ...
                        I guess I don't have the modeling skills to satisfy any type of export to Thea. I have exausted my experiments including loading, reloading all applications, so for now with sadness I am putting Thea away.
                        If anyone has suggestions on another engine that will work well in the context of this boat project please let me know. I am aware of popular engines sold here but not sure how to pick anymore.
                        What is the problem? Is it just the material application?
                        Could you post up the model here and see if someone else with Thea can test it?
                          boofredlay
                          After a quick look I don't see the problem. I don't see any extra faces in Thea.
                          Here is a view from SU and one from Thea with some materials applied.
                          (I only have the trial of Thea at work hence the watermark).
                          • N Offline
                            notareal
                            Have to agree with Boo, when looking the model I don't see any particular reasons why it should not export perfectly. For me the scene works just fine 😕 . Use of single sided geometry may cause issues with adaptive BSD, but for progressive BSD and unbiased TR1/TR2 it's not a issue. But it would not explain "coloring" issues... I'd say that the model is fine.
                            Only one good reason I can figure is that SU2TH does not recognize the license. If that's the case, then SU2TH is run in demo mode and if you have licensed Thea, then material from random triangles is dropped. Please verify the license...
                            In command prompt
                            In Mac try open -a Thea.app --args thea -license sketchup -matlab
                            In windows try Thea.exe thea -license sketchup -matlab
                            If matlab opens in demo mode, then something has gone wrong with the license.
                            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                              boofredlay
                              Good luck and happy rendering, that is an order 😉
                                boofredlay
                                Hang in there.
                                  KarinaGM
                                  Loving it!
                                  **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                                  -Benjamín Franklin.**
                                  • numbthumbN Offline
                                    numbthumb
                                    Can´t believe I missed this. Excellent work! 👍
                                    Comfortably numb...
                                    • N Offline
                                      notareal
                                      Maybe a underwater render with that material, broken windows...
                                        KarinaGM
                                        Wooowow
                                        And you say you need assistance?
                                        The 1st image of this last message is just great!
                                          numbthumb
                                          You´ve tied this one pretty well 😉
                                          Comfortably numb...
                                            numbthumb
                                            And how did you make your water?
                                            Comfortably numb...
