    Island Queen
    38 Posts 13 Posters 15.2k Views 13 Watching
    • KrisidiousK Offline
      Krisidious
      Vue and the 3D simulator I mentioned...
      By: Kristoff Rand
        d12dozr
        This one has worked well for me: ($49.95) http://www.cornucopia3d.com/purchase.php?item_id=8911
        http://goo.gl/f7ooYh
        • boofredlayB Offline
          boofredlay
          Funny think happened on the way to rendering this project. ...
          I guess I don't have the modeling skills to satisfy any type of export to Thea. I have exausted my experiments including loading, reloading all applications, so for now with sadness I am putting Thea away.
          If anyone has suggestions on another engine that will work well in the context of this boat project please let me know. I am aware of popular engines sold here but not sure how to pick anymore.
          What is the problem? Is it just the material application?
          Could you post up the model here and see if someone else with Thea can test it?
            boofredlay
            After a quick look I don't see the problem. I don't see any extra faces in Thea.
            Here is a view from SU and one from Thea with some materials applied.
            (I only have the trial of Thea at work hence the watermark).
            • N Offline
              notareal
              Have to agree with Boo, when looking the model I don't see any particular reasons why it should not export perfectly. For me the scene works just fine 😕 . Use of single sided geometry may cause issues with adaptive BSD, but for progressive BSD and unbiased TR1/TR2 it's not a issue. But it would not explain "coloring" issues... I'd say that the model is fine.
              Only one good reason I can figure is that SU2TH does not recognize the license. If that's the case, then SU2TH is run in demo mode and if you have licensed Thea, then material from random triangles is dropped. Please verify the license...
              In command prompt
              In Mac try open -a Thea.app --args thea -license sketchup -matlab
              In windows try Thea.exe thea -license sketchup -matlab
              If matlab opens in demo mode, then something has gone wrong with the license.
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                boofredlay
                Good luck and happy rendering, that is an order 😉
                  boofredlay
                  Hang in there.
                    KarinaGM
                    Loving it!
                    **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                    -Benjamín Franklin.**
                    • numbthumbN Offline
                      numbthumb
                      Can´t believe I missed this. Excellent work! 👍
                      Comfortably numb...
                      • N Offline
                        notareal
                        Maybe a underwater render with that material, broken windows...
                          KarinaGM
                          Wooowow
                          And you say you need assistance?
                          The 1st image of this last message is just great!
                            numbthumb
                            You´ve tied this one pretty well 😉
                            Comfortably numb...
                              numbthumb
                              And how did you make your water?
                              Comfortably numb...
                                numbthumb
                                Thanks for the thorough response.
                                Comfortably numb...
                                • Bryan KB Offline
                                  Wow. Looking better and better.
                                    agamemnus
                                    Nice water. Needs a different font though.
                                    Font needs more spacing between letters and wider&thicker letters. That better matches the real ship and would look better I think.
                                    • Bryan KB Offline
                                      Looks great, except there is something about the water...
                                      Scale?
                                      • axeonaliasA Offline
                                        axeonalias
                                        Shes Looking Great, love the reflections on the hull, Very clean 😄 More renders!!!
                                        https://sketchfab.com/Axeonalias
                                          lapx
                                          Pin stripe could add further detail. Looks great!
                                          • Bryan KB Offline
                                            The camera is almost in the water...I better lift it out before it gets wet.. 😄
                                            Thanks Bryan!
                                            Ah! 😄
                                            • 2 / 2
