    [Plugin]$ Keyframe Animation
    150 Posts 39 Posters 148.7k Views 39 Watching
    • C
      cperkins
      nice tutorial tbg. I've been editing the actual .xml file to change max iterations on progressive settings.. your way is much easier 👍
      Have your tried exporting to Kerky after creating the .tweens file? I used su2kt's batch scene export and got it over fine but the resolution doesn't hold. It ends up being about 200x200 every time. Maybe it's something I overlooked. I'm pretty sure I've been choosing the 'match scene resolution' option from the export dialog.
      • T
        tallbridgeguy
        Hi cperkins, I have exported tween files with su2kt and it worked great.
        BUT I have only used the setting in the dialog like 640x480, 800x600...not the match scene option. I will give it a try tonight and see what happens? I am sorta surprised we can't change it later in KT to anything we want?
        Maybe check your camera setting and see if it set to 200x200 the default?
        s
        Nielsen
        http://www.tallbridgeguy.com/
        • P
          peweuk
          Great plug-in - but can anyone tell me why the exported video (attached is output from SU 8 using V1.4) is so blurry at the edges.
          router.avi
          I must be missing a setting or something somewhere 😳
            Regular Polygon
            Hi peweuk,
            The most likely culprit is the anti-alias setting in the Options dialog. If you don't check it, the edges will be quite blurry.
            My SketchUp Plugins
            • P
              peweuk
              I already tried that - the video I attached had Anti-alias switched on (it is exactly the same as when it is switched off). 😞
                Regular Polygon
                My only other guess is that the edge styles might have an effect. All edges are a little blurry. So, the thinner they are, the better. I would turn off things like Profiles, Depth cue, etc., and see if that improves the quality.
                My SketchUp Plugins
                • P
                  peweuk
                  Unfortunately everything is turned off -
                  where is the thickness setting?
                  • rohallorahR
                    rohallorah
                    @regular polygon said:
                    Hi Everyone,
                    Just thought I'd mention that version 1.4 is available. There is now a toolbar to facilitate the animation process. Here's a screenshot:
                    [attachment=0:269n9yz7]<!-- ia0 -->toolbar overview.png<!-- ia0 -->[/attachment:269n9yz7]
                    Look forward to trying out the new version!!
                    Robert O'Halloran
                    "Interior Architect & Designer"
                    http://designermedia.ie
                    • E
                      Ecuadorian
                      Is there a way to export these animations as FBX?
                      -Miguel Lescano
                      • MarianM
                        Marian
                        I had an Idea today 😛. Would it be possible for the plugin to detect scale deformations or other modifications to the mesh not only its position? Now that would make it a game changer 😄
                          Regular Polygon
                          Thanks for your suggestion. 👍
                          Yeah, right now Keyframe detects changes in the position and orientation of objects between scenes, and animates them by interpolating those properties. Currently, it ignores the size. But it wouldn’t be so difficult to detect changes in scale, and interpolate those values as well.
                          I’ll put it on my list of planned updates. I am just wondering how often this feature is required. If I get more feedback in favor of animating the size of objects, I’ll up the priority.
                          My SketchUp Plugins
                          • MarianM
                            Marian
                            Awesome 😄
                            • andybotA
                              andybot
                              I just bought your plugin, and it is fantastic! What sold me was a rendered video posted here, but now I can't find the post, of a building flying together. I think having the scale function would be really great. I am so excited that this plugin works with Twilight, I am able to do in sketchup what would take me a lot longer to setup up in other more costly software.
                                Regular Polygon
                                @andybot:
                                Thank you!
                                I’m glad you are finding the plugin useful. 😄
                                My SketchUp Plugins
                                • monsterzeroM
                                  monsterzero
                                  Adding scale and vert animation would be powerful. Squash and stretch are essential for character animation. That would be awesome!
                                  monsterzero
                                  I live stream my work on my graphic novel:
                                  https://www.youtube.com/@monsterz3r0
                                  http://infinitemachine.tv/
                                  https://www.aaatitle.xyz/
                                  • mariochaM
                                    mariocha
                                    Count my vote in. 😄
                                    %(#008000)[Mario C.
                                    • mariochaM
                                      mariocha
                                      Anyone knows if there are issues with Keyframe on MacOS Lion ?
                                      %(#008000)[Mario C.
                                      • GaieusG
                                        What have you in mind, Miguel? 😉
                                        • E
                                          Ecuadorian
                                          Importing it in Lumion, of course.
                                          -Miguel Lescano
                                            Regular Polygon
                                            There have been a few updates to Keyframe Animation since it was released three months ago. The current version is 1.3. The plug-in and user manual are available on the Download Page.
                                            Version 1.1 made improvements to much of the code. A new algorithm generates the in between scenes over twice as fast as the original. They are important because you can export the tween scenes to an AVI movie.
                                            Versions 1.2 and 1.3 have simplified the process for creating an animation. You no longer need to assign a unique name to each instance that you want to animate – that seemed to be the least intuitive, most tedious step in the whole process. The script will now automatically distinguish which instances are active and which are static. You don’t have to do anything.
                                            The basic workflow can be summarized in five easy steps:
                                            1. Add some scenes.
                                            2. Select the first scene.
                                            3. Move the objects where you want them.
                                            4. Record the position data.
                                            5. Select the next scene, and go to step 3.
                                            This video tutorial illustrates the new workflow in version 1.3, and in the process, shows how to animate a Rubik’s Cube.
                                            [flash=640,510:5q5jjjp5]http://www.youtube.com/v/ZmNmQ3izNnI?fs=1&amp;hl=en_US&amp;rel=0[/flash:5q5jjjp5]
                                            My SketchUp Plugins
                                            • 4 / 8
