    [Plugin]$ Keyframe Animation
    150 Posts 39 Posters 146.2k Views 39 Watching
      dtrarch
      Hello tfdesign
      On the price please.
      We are all conditioned to the generousity of our friends here on the Forum and perhaps just expect everything to be for free.
      Keyframe Animation is offered as a commercial plugin and if it is to be used as tool for professional work and profit the price seems more than fair.
      It the use is just for fun then one must just accept that it is a pay to play deal and affordability is moot.
      Perhaps a fair rule for use is to either pay if asked for or at least thank the authors for those plugins that one actually uses.
      There really is no such thing as the proverbial free lunch.
      What a treasure this SuperForum is.
      My most personal thanks from to all who share their creative skills and generous good help here on this Forum.
      We all know who you are. πŸ‘
      dtr
        Regular Polygon
        @tallbridgeguy said:
        Thanks for fixing it! I will give it another go.
        Update: It works great now!
        Update: I got it to work in kerkythea.
        I am glad that solved the problem. Thanks for the update. πŸ‘
        @cperkins said:
        youdaman! 😎 Sketchup stock just jumped 10 points! Here's a quick one exported from Sketchup, animating 4 levels deep. I'll post a rendered version later on. Thanks again!
        That animation is great! 😲 ❗
        It is a good example of nested animated components. Thanks for sharing your work. πŸ‘
        My SketchUp Plugins
        • T
          tallbridgeguy
          Hi is the download link broken for windows?
          s
          Nielsen
          http://www.tallbridgeguy.com/
            Regular Polygon
            Well, that is strange. Firefox downloads the installer just fine. But IE claims the file is not found. πŸ˜•
            OK, the link on the Download page should work for either browser now. I zipped up the installer, and IE seems to be content.
            @tallbridgeguy:
            Thanks for that. πŸ‘
            My SketchUp Plugins
            • T
              tallbridgeguy
              No problem, I have been playing with the plugin. It works great!
              Nielsen
              • T
                tallbridgeguy
                Here is a quick tutorial I made showing what I am doing.
                If you watch it full screen at 720p it is tolerable....
                YouTube - tallbridgeguy-keyframe animation Tutorial
                [flash=853,510:2nvj5w9m]http://www.youtube.com/v/UxUMMdSJTgs?fs=1&hl=en_US[/flash:2nvj5w9m]
                Nielsen
                  Regular Polygon
                  Thanks for the tutorial. I learned some things about using Kerkythea. β˜€
                  The plugin to export the animation to Kerkythea is su2kt.rb by Tomasz. It works great, but you still have to stitch together the images generated by Kerkythea to make a movie, which is one more step.
                  If rendering is not required, there is a quick way to export your animation directly from SketchUp. Just create the tween scenes using the Keyframe Animation plugin. Then export the tweens to a movie using the SketchUp utility, File > Export > Animation.
                  My SketchUp Plugins
                  • C
                    cperkins
                    nice tutorial tbg. I've been editing the actual .xml file to change max iterations on progressive settings.. your way is much easier πŸ‘
                    Have your tried exporting to Kerky after creating the .tweens file? I used su2kt's batch scene export and got it over fine but the resolution doesn't hold. It ends up being about 200x200 every time. Maybe it's something I overlooked. I'm pretty sure I've been choosing the 'match scene resolution' option from the export dialog.
                    • T
                      tallbridgeguy
                      Hi cperkins, I have exported tween files with su2kt and it worked great.
                      BUT I have only used the setting in the dialog like 640x480, 800x600...not the match scene option. I will give it a try tonight and see what happens? I am sorta surprised we can't change it later in KT to anything we want?
                      Maybe check your camera setting and see if it set to 200x200 the default?
                      s
                      Nielsen
                      • P
                        peweuk
                        Great plug-in - but can anyone tell me why the exported video (attached is output from SU 8 using V1.4) is so blurry at the edges.
                        router.avi
                        I must be missing a setting or something somewhere 😳
                          Regular Polygon
                          Hi peweuk,
                          The most likely culprit is the anti-alias setting in the Options dialog. If you don't check it, the edges will be quite blurry.
                          My SketchUp Plugins
                          • P
                            peweuk
                            I already tried that - the video I attached had Anti-alias switched on (it is exactly the same as when it is switched off). 😞
                              Regular Polygon
                              My only other guess is that the edge styles might have an effect. All edges are a little blurry. So, the thinner they are, the better. I would turn off things like Profiles, Depth cue, etc., and see if that improves the quality.
                              My SketchUp Plugins
                              • P
                                peweuk
                                Unfortunately everything is turned off -
                                where is the thickness setting?
                                • rohallorahR
                                  rohallorah
                                  @regular polygon said:
                                  Hi Everyone,
                                  Just thought I'd mention that version 1.4 is available. There is now a toolbar to facilitate the animation process. Here's a screenshot:
                                  [attachment=0:269n9yz7]<!-- ia0 -->toolbar overview.png<!-- ia0 -->[/attachment:269n9yz7]
                                  Look forward to trying out the new version!!
                                  Robert O'Halloran
                                  "Interior Architect & Designer"
                                  http://designermedia.ie
                                  • E
                                    Ecuadorian
                                    Is there a way to export these animations as FBX?
                                    -Miguel Lescano
                                    • MarianM
                                      Marian
                                      I had an Idea today πŸ˜›. Would it be possible for the plugin to detect scale deformations or other modifications to the mesh not only its position? Now that would make it a game changer πŸ˜„
                                        Regular Polygon
                                        Thanks for your suggestion. πŸ‘
                                        Yeah, right now Keyframe detects changes in the position and orientation of objects between scenes, and animates them by interpolating those properties. Currently, it ignores the size. But it wouldn’t be so difficult to detect changes in scale, and interpolate those values as well.
                                        I’ll put it on my list of planned updates. I am just wondering how often this feature is required. If I get more feedback in favor of animating the size of objects, I’ll up the priority.
                                        My SketchUp Plugins
                                        • MarianM
                                          Marian
                                          Awesome πŸ˜„
                                          • andybotA
                                            andybot
                                            I just bought your plugin, and it is fantastic! What sold me was a rendered video posted here, but now I can't find the post, of a building flying together. I think having the scale function would be really great. I am so excited that this plugin works with Twilight, I am able to do in sketchup what would take me a lot longer to setup up in other more costly software.
                                            • 4 / 8
