    E-on-Lumenrt render for Sketchup
    extensions
    102 Posts 27 Posters 36.2k Views 27 Watching
    • P
      Panga
      No,
      I'm still unable to produce anything with it as the fix for my graphic card is not released yet...or did I miss something ?? Two or Three weeks after buying it... 😠
        dbalex
        I'm sorry to hear that, I keep thinking it's strange to not release a demo of the soft to try before buying, anyway I hope your problem will get solved quickly.
        http://www.bocostudio.com
        • E
          Ecuadorian
          It's even stranger being completely unable to see the forum before buying.
          -Miguel Lescano
            dbalex
            yes indeed, it looks like they have something to hide
            • GaieusG
              Hi guys, here is a very quick and dirty example (probably e-on would not be proud of) I made when testing bump and reflection maps.
              http://dl.dropbox.com/u/25025526/Untitled.exe (Mac users, sorry but I did not export a Mac compatible version yet as I could not test it anyway)
              Note two things when loading:
              • the scene is a bit off my ground plane so if you start walking around, scroll a bit to zoom in and only then click the mouse.
              • LumenRT places your scene onto its ground based on the lowest point (in my case, the bottom of the pool) of the model so you can easily "fall off" if you have basements or such, deep pools (certainly I should have added a bigger ground plane to the model but again, it was just for a quick test, nothing "real" as a presentation)
                Press F1 to see all navigation and other options. Note that this model does not have SU scenes so exporting animation or playing it in kiosk mode is not possible (that was not part of my testing).
              I should probably make some better model/example to show. Here is what you can "expect".
              • jamalitoJ
                jamalito
                I liked to works Vue and it Versions
                but
                Will it be a good rival for Vray RT ?
                Albert Einstein:
                ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                • GaieusG
                  I cannot compare as I do not know Vray RT (to be honest, did not even know there is one).
                  • jamalitoJ
                    jamalito
                    @jamalito said:
                    no Mr Gaieus there are Vray RT and they release Vray RT 2.0 demo true I see it in Vray Max right now I don't know is there version to SU in true i wish ?
                    you can see this Tutorial For Vray RT
                    http://youtu.be/KOHcTDyR44o
                    Albert Einstein:
                      dbalex
                      thanks gaieus for this little test, it's still not revolutionary I would say, maybe with more time you could achieve better results. Can you choose between multiple presets for the environment or you have just one? Can you render movies or is it only for realtime presentations to move around in your model?
                      • GaieusG
                        There are more environment presets (neutral white, bad weather, nce weather - the one I exported - blue sky - with no clouds).
                        Also note that the above render was made with the poorest quality available (draft) and there are three more "levels".
                        If your model has animation scenes, after you launch the viewer, it will automatically start playing it. You can also export those animations just like a SU movie.
                          dbalex
                          ok so it looks like it's better than I thought, mmmh I'm tempted but as student I think it's still a little expensive for something I will not use everyday. Thanks Gaieus!
                          • N
                            Nicholas Phelps
                            Panga,
                            There's a user on the e-on registered forum who has a problem very similar to yours. The latest update appears to have solved his problem. Did you give it a try?
                            Best regards
                              dburdick
                              @panga said:
                              No,
                              Hi Panga, were you able to get this problem resolved for your graphics card?
                              • P
                                Panga
                                Yes I was the user on e-on forums that encountered the issue ! Everything is fine with my graphic board now. 😉
                                  dbalex
                                  nice to hear! hope to see some rendered livecubes 😉
                                    dburdick
                                    Hi Everyone,
                                    Just a heads up. There's a new update for LumenRT coming out this week. It includes a greatly improved ability to render very large models more efficiently with much better performance. More details are forthcoming on this later after the update is released.
                                      dbalex
                                      will there be a demo too?
                                      • PixeroP
                                        Pixero
                                        +1
                                        • E
                                          Ecuadorian
                                          Will we be able to have a look at the forum before purchasing?
                                          -Miguel Lescano
                                          • N
                                            Nicholas Phelps
                                            Ecuadorian,
                                            Yes, we've been wanting to open up our registered user forum for a while but haven't gotten around to doing it yet (it requires some work on the forum engine to let everybody read, but only let those who have a registered copy post).
                                            We'll bump the priority on this a little more 😄
                                            Best regards
                                            • 4 / 6
