    E-on-Lumenrt render for Sketchup
    extensions
    102 Posts 27 Posters 36.2k Views 27 Watching
    • E
      Ecuadorian
      Yikes... All the house animations I make have more than 600K edges and 300+ textures. I've been using LightUp so far but I had hoped to improve them with Lumen, adding raytraced reflections and sharper sun shadows.
      Looks like I'll have to wait.
      -Miguel Lescano
      • GaieusG
        I exported a model in the screenshot quite quickly (see also statistics) although the materials used are mostly low res, small tiles and I did not even tweak any of them (with special bumps or reflection).
        Navigating in the exported live cube goes pretty well although not without minor lags. nvidia geforce 9600 GT (1Gb) on 32 bit system.
        • AdamBA
          AdamB
          FYI: LightUp is adding planar reflections just like lumenRT uses. 😉
            dburdick
            @panga said:
            Yes I'm on Win7 64 bits SP1. But All liveCubes are not working. I have an error message saying that my graphic card is not compatible even if my system fulfil the requirements.
            Hi Panga,
            Can you visit the e-on Tech support page and enter a bug report on your issue with the Quadro 1800 graphics card. LumenRT should work fine with this card. Here's the link:
            http://www.e-onsoftware.com/support/TechSupport.php
            • B
              bravoddb
              where can I buy nice 3d trees? so I can use it with Lumen RT
                dbalex
                Do you guys have something rendered in lumenrt you can show us? I would love to see something made by real users, not those demo stuff 😉
                http://www.bocostudio.com
                • P
                  Panga
                  No,
                  I'm still unable to produce anything with it as the fix for my graphic card is not released yet...or did I miss something ?? Two or Three weeks after buying it... 😠
                    dbalex
                    I'm sorry to hear that, I keep thinking it's strange to not release a demo of the soft to try before buying, anyway I hope your problem will get solved quickly.
                    • E
                      Ecuadorian
                      It's even stranger being completely unable to see the forum before buying.
                      -Miguel Lescano
                        dbalex
                        yes indeed, it looks like they have something to hide
                        • GaieusG
                          Hi guys, here is a very quick and dirty example (probably e-on would not be proud of) I made when testing bump and reflection maps.
                          http://dl.dropbox.com/u/25025526/Untitled.exe (Mac users, sorry but I did not export a Mac compatible version yet as I could not test it anyway)
                          Note two things when loading:
                          • the scene is a bit off my ground plane so if you start walking around, scroll a bit to zoom in and only then click the mouse.
                          • LumenRT places your scene onto its ground based on the lowest point (in my case, the bottom of the pool) of the model so you can easily "fall off" if you have basements or such, deep pools (certainly I should have added a bigger ground plane to the model but again, it was just for a quick test, nothing "real" as a presentation)
                            Press F1 to see all navigation and other options. Note that this model does not have SU scenes so exporting animation or playing it in kiosk mode is not possible (that was not part of my testing).
                          I should probably make some better model/example to show. Here is what you can "expect".
                          • jamalitoJ
                            jamalito
                            I liked to works Vue and it Versions
                            but
                            Will it be a good rival for Vray RT ?
                            Albert Einstein:
                            ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                            • GaieusG
                              I cannot compare as I do not know Vray RT (to be honest, did not even know there is one).
                              • jamalitoJ
                                jamalito
                                @jamalito said:
                                no Mr Gaieus there are Vray RT and they release Vray RT 2.0 demo true I see it in Vray Max right now I don't know is there version to SU in true i wish ?
                                you can see this Tutorial For Vray RT
                                http://youtu.be/KOHcTDyR44o
                                Albert Einstein:
                                  dbalex
                                  thanks gaieus for this little test, it's still not revolutionary I would say, maybe with more time you could achieve better results. Can you choose between multiple presets for the environment or you have just one? Can you render movies or is it only for realtime presentations to move around in your model?
                                  • GaieusG
                                    There are more environment presets (neutral white, bad weather, nce weather - the one I exported - blue sky - with no clouds).
                                    Also note that the above render was made with the poorest quality available (draft) and there are three more "levels".
                                    If your model has animation scenes, after you launch the viewer, it will automatically start playing it. You can also export those animations just like a SU movie.
                                      dbalex
                                      ok so it looks like it's better than I thought, mmmh I'm tempted but as student I think it's still a little expensive for something I will not use everyday. Thanks Gaieus!
                                      • N
                                        Nicholas Phelps
                                        Panga,
                                        There's a user on the e-on registered forum who has a problem very similar to yours. The latest update appears to have solved his problem. Did you give it a try?
                                        Best regards
                                          dburdick
                                          @panga said:
                                          No,
                                          Hi Panga, were you able to get this problem resolved for your graphics card?
                                          • P
                                            Panga
                                            Yes I was the user on e-on forums that encountered the issue ! Everything is fine with my graphic board now. 😉
                                            • 3 / 6
